Cerwin-Vega CVi-152 15" 2-Way Full-Range PA Speaker
Brand:|Model: CVi-152|Part # 246-418
When you need high output and excellent sound quality for your pro audio application and only the best will do, you turn to Cerwin-Vega! The CVi-152 features a 15" woofer and 1" compression driver, and is fully suited to support both live and recorded source material.
List Price$589.00
You Save41%
Part # 246-418
  • High power, reflex-loaded 15" transducer
  • Smooth 1" high frequency compression driver
  • Loud! -- 129 dB SPL calculated maximum output (@ 1m)
  • Genuine Neutrik® Speakon® NL4 connectors
  • Slave output for daisy-chaining
The CVi-152 is a portable, full range, fifteen-inch 2-way main loudspeaker system designed for professional live music and playback applications.
This powerful two-way design features a cast frame fifteen inch transducer with a 2.5" voice coil to handle the low and low/midrange frequencies and a 1" PETP (polyethylene terephthalate) diaphragm compression driver mounted to a 80° H x 50° V hemi-conical horn for smooth, accurate on and off axis high frequency performance. Advanced crossover network designs are employed for coherent cross-band summation throughout the coverage pattern.
The entire CVi series is equipped with two Neutrik® Speakon® NL4 and two 1/4" input/outputs (parallel) per enclosure to facilitate daisy-chain configurations. This PA speaker also features a 1-3/8" pole-mount socket for stand mounting or pole mounting to a subwoofer.
Power handling:
250 watts RMS, 500 watts program, 1,000 watts peak
Frequency response:69-12,000 Hz (-3 dB), 45-20,000 Hz (-10 dB)
Calculated max output:
129 dB
Nominal directivity:
-6 dB points, horizontal 80°, vertical 50°
Axial sensitivity:
99 dB (1W/1m)
Nominal impedance:
8 ohms
29" x 18.5" x 17.25"
59.5 lbs.
  • Woofer Size15"
  • BrandCerwin-Vega
  • ModelCVi-152
  • Part Number246-418
  • UPC743658901274
    (1 Reviews)
  • Weight69 lbs.
View similar products to the Cerwin-Vega CVi-152 15" 2-Way Full-Range PA Speaker
