Cerwin-Vega CVi-122m 12" 2-Way Passive PA Floor Monitor Speaker
Brand:|Model: CVi-122m|Part # 246-420
When you need high output and excellent sound quality for your pro audio application and only the best will do, you turn to Cerwin-Vega! The CVi-122m features a 12" woofer and 1" compression driver and is suitable for stage monitor and mains duties.
Part # 246-420
  • High output reflex-loaded 12" low frequency transducer
  • Smooth 1" high frequency compression driver
  • Loud! -- 129 dB SPL calculated maximum output (@ 1m)
  • Genuine Neutrik® Speakon® NL4 connectors
  • Slave output for daisy-chaining
The CVi-122m is a portable, full range, twelve-inch 2-way stage monitor / main loudspeaker system designed for live music and playback applications.
This awesome monitor features a cast frame twelve inch transducer with a 2.5" voice coil to handle the low and low/midrange frequencies and a 1" PETP (polyethylene terephthalate) diaphragm compression driver mounted to a 80° H x 50° V hemi-conical horn for smooth, accurate on and off axis high frequency performance. Advanced crossover network designs are employed for coherent cross-band summation throughout the coverage pattern.
The entire CVi series is equipped with two Neutrik® Speakon® NL4 and two 1/4" input/outputs (parallel) per enclosure to facilitate daisy-chain configurations. This PA monitor also features a 1-3/8" pole-mount socket for stand mounting or pole mounting to a subwoofer.
Power handling:
250 watts RMS, 1000 watts peak
Frequency response:69-16,000 Hz (-3 dB), 53-20,00 Hz (-10 dB)
Calculated max output:
128 dB
Nominal directivity:
-6 dB points, horizontal 80°, vertical 50°
Axial sensitivity:
98 dB (1W/1m)
Nominal impedance:
8 ohms
Dimensions:
20.5" x 15.75" x 25.25"
Weight:
47 lbs.
  • ConfigurationStage Monitor
  • Woofer Size12"
  • BrandCerwin-Vega
  • ModelCVi-122m
  • Part Number246-420
  • UPC743658901267
  • Weight54 lbs.
View similar products to the Cerwin-Vega CVi-122m 12" 2-Way Passive PA Floor Monitor Speaker
