Cerwin-Vega CVA-118X 18" Active PA Subwoofer 700W RMS
Brand:| Model: CVA-118X
This active subwoofer is built around a custom designed 18" Cerwin-Vega woofer with extreme power handling of 1,400 watts peak.
  • Custom 18" Cerwin-Vega woofer
  • More bass in less space (18" driver in 15" cabinet footprint)
  • Built-in system amplification (700 watts RMS/1,400 watts Peak)
  • 4-Position high pass filter
  • Sweepable low pass filter
  • Scalable with multiple subs using master/ slave output
  • Cast aluminum grille
246-402
Weight: 125 lbs.
ORDER TODAY
Ships in 7-10 Business Days
List Price$1,499.00
You Save40%
ShippingTRUCK ONLY
$899.00
Part # 246-402
The CVA-118 shares many of the features and benefits found in its bigger 21" brother, but with an even more compact enclosure. The CVA-118 is a high-performance, compact 18" active subwoofer with an integrated 700 watt amplifier. The legendary Cerwin-Vega woofer design is reflected in this 18" woofer offering maximum bass performance with extreme power, handling and exceptional low-frequency response. The CVA-118 features built-in amplification for an integrated all-in-one solution with a powerful 1,400 watt of peak power output.
A unique and striking cast aluminum grille protects the woofer while doubling as a heat-sink to minimize power compression and optimizing driver performance. Housed in a compact hardwood enclosure designed the size of a standard 15" subwoofer footprint, the CVA-118 is highly portable and durable with the option of a durable Coolex® polyurethane paint or high-grade black carpet finish. Along with XLR and 1/4" TRS connectors, the CVA-118 has Master/Slave output connectors that allow for multiple CVA subwoofers to be daisy-chained together using a single signal. This compact active sub also features a 35 mm pole-mount socket to accommodate a satellite speaker for full-range performance.
Of course, flexible input connections, daisy-chain capability, and mounting accessories makes the CVA-118 the perfect first choice when building an easy to use, flexible and powerful bottom end foundation.
Power handling
700 watts continuous/1,400 watts peak
Frequency response39 Hz - 135 kHz (±3 dB)
Frequency range
36 Hz - 135 kHz (-10 dB)
Max SPL
131 dB
Input connectors
XLR/F balanced 1/4" TRS
Output connectors
XLR/M 1/4" TRS
Crossover
LPF Continuously variable from 65 Hz - 130 Hz
HPF Selectable output 65 Hz, 85 Hz, 130 Hz, or bypass
Voice coil
3"
Dimensions
25" x 21" x 23.5"
Weight
121 lbs.
  • Speaker TypeActive / Powered
  • ConfigurationSubwoofer
  • Woofer Size18"
  • BrandCerwin-Vega
  • ModelCVA-118X
  • Part Number246-402
  • UPC743658900697
  • Weight125 lbs.
View similar products to the Cerwin-Vega CVA-118X 18" Active PA Subwoofer 700W RMS
My CVA-118X stays on "protected" mode. Any idea what the solution is?
Asked by: PiCH
There is nothing in the manual that explains what to do if this light comes on, and it could be cause by many different things. I would recommend contacting Cerwin Vega directly for more help with this problem.
Date published: 2014-09-25
  • 2015-04-18T09:50CST
  • loc_en_US, sid_246-402, PRD, sort_recentQuestionsFirst
Customer projects that include: Cerwin-Vega CVA-118X 18" Active PA Subwoofer 700W RMS
