Cerwin-Vega CV-2800 2800W Professional Power Amplifier
Brand:|Model: CV-2800-NA|Part # 246-427
The Cerwin-Vega CV-2800 high performance pro power amplifiers are for those that want to muscle through the most demanding audio challenges!
- Order Soon - Only 1 Left In StockMore Due In February 19, 2016
List Price$839.00
You Save41%
$499.00
Part # 246-427
  • Front panel LED displays indicate power, clip protect and signal status
  • Balanced XLR and TRS Input connectors
  • Speakon NL-4 locking output connectors and binding posts
  • Detented 21-position input level control knobs
  • Defeatable limiter and high pass filter per channel
  • Short circuit, thermal, current limit, DC offset, current inrush, RF protection, Turn on/ Turn off muting protection
The CV-2800 power amplifier by Cerwin-Vega is rugged and has the muscle to accommodate the most demanding audio challenges. With a power rating of up to 2800 watts, exceptional THD (Total Harmonic Distortion) and high damping factor, this pro amplifier is the right choice for a wide range of music and home theater applications.
To ensure reliable operation, Cerwin-Vega's amps include a highly efficient variable speed tunnel cooling system that dynamically follows amplifier output levels. The 21-position detent gain control knobs help you set and maintain volume settings. Signal and clip indicators provide a convenient way to monitor the amplifier's status.
Specifications: • Stereo power output: 600 watts at 8 ohms; 900 watts at 4 ohms; 1400 watts at 2 ohms • Mono power output: 1800 watts at 8 ohms; 2800 watts at 4 ohms • Signal-to-noise ratio: 104dB (20Hz-20kHz)• Frequency response: 20Hz-20kHz (0/-0.5dB); 5Hz-60kHz (0/-3dB)• Damping factor: 350 (@400 Hz) • Input impedance: 15k ohms • Distortion (SMPTE-IM): .04% • Dimensions: 19" x 3.5" x 16.5"
  • Power Output (RMS Per Channel @ 8 ohms)900 Watts
  • Output Channels2
  • Weight Range40 to 49 lbs.
  • BrandCerwin-Vega
  • ModelCV-2800-NA
  • Part Number246-427
  • UPC743658900567
    (1 Reviews)
  • Weight55.2 lbs.
View similar products to the Cerwin-Vega CV-2800 2800W Professional Power Amplifier
Cerwin-Vega CV-2800 2800W Professional Power Amplifier is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from love it,but ?.I am using this amp to power two DAyton12ho subs in seperate cabs for home theater set up.The cv-2800 powers these power hungry subs no problem.Subs have lots of punch and I am very happy with the sound,no hums or any other noise.Input sensativity is low enough that I don't need to boost signal. Could only give 4 stars because the fan is too noisy for me.The variable speed fan did not run at all when I first powered up the amp,but once it turned on it never shut off again even over long periods of power down.Turn it on and you get the fan stone cold.It is not over powering but its there when the sound is low.I have surely heard much more fan noise from other amps.Love this amp but I think it will move to the back subs where I cant here the fan.note;no fan noise think XLS.
Date published: 2013-05-06
  • 2016-02-08T06:43CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_246-427, PRD, sort_mostRecent
is this amp 600 watts stereo into 8 ohms or 900 watts? the product specs say both
Asked by: 1111
This amplifier produces 600 watts RMS into 8 ohms per channel.
Date published: 2015-12-28
Is this amp switchable to 220v US?
Asked by: Tory
This amp is 110VAC input only.
Date published: 2015-11-30
will this amp be stable 1or 2 ohm load per chanel into 2 15 inch subs wired in parellel l
Asked by: 18787
This amplifier is only stable to 2 ohms per channel in stereo mode and 4 ohms in bridged mode.
Date published: 2014-03-27
  • 2016-02-08T07:23CST
  • loc_en_US, sid_246-427, PRD, sort_recentQuestionsFirst
