Cerwin-Vega CV-1800 800W Professional Power Amplifier
Brand:|Model: CV-1800-NA|Part # 246-426
The Cerwin-Vega CV-1800 high performance pro power amplifiers are for those that want to muscle through the most demanding audio challenges!
- Order Soon - Only 3 Left In Stock
List Price$669.00
You Save40%
$399.00
Part # 246-426
  • Front panel LED displays indicate power, clip protect and signal status
  • Balanced XLR and 1/4" TRS input connectors
  • Speakon NL-4 locking output connectors and binding posts
  • Detented 21-position input level control knobs
  • Defeatable limiter and high pass filter per channel
  • Flow-through cooling design prevents overheating with continuously variable speed, front to rear
  • Short circuit, thermal, current limit, DC offset, current inrush, RF protection, Turn on/ Turn off muting protection
The CV-1800 power amplifier by Cerwin-Vega is rugged and has the muscle to accommodate the most demanding audio challenges. With a power rating of up to 2800 watts, exceptional THD (Total Harmonic Distortion) and high damping factor, this pro amplifier is the right choice for a wide range of music and home theater applications.
To ensure reliable operation, Cerwin-Vega's amps include a highly efficient variable speed tunnel cooling system that dynamically follows amplifier output levels. The 21-position detent gain control knobs help you set and maintain volume settings. Signal and clip indicators provide a convenient way to monitor the amplifier's status.
Specifications: • Stereo power output: 400 watts at 8 ohms; 600 watts at 4 ohms; 900 watts at 2 ohms • Mono power output: 1200 watts at 8 ohms; 1800 watts at 4 ohms • Signal-to-noise ratio: 120dB (20Hz-20kHz) • Frequency response: 20Hz-20KHz (0/-0.5dB); 5Hz-60KHz (0/-3dB) • Damping factor: 280 (@ 400 Hz) • Input impedance: 15k ohms • Distortion (SMPTE-IM): 0.01% • Dimensions: 19" x 3.5" x 16.5"
  • Power Output (RMS Per Channel @ 8 ohms)400 watts Watts
  • Output Channels2
  • Weight Range40 to 49 lbs.
  • BrandCerwin-Vega
  • ModelCV-1800-NA
  • Part Number246-426
  • UPC743658900536
  • Weight49.75 lbs.
View similar products to the Cerwin-Vega CV-1800 800W Professional Power Amplifier
