Cerwin-Vega AB-36C Stroker 18" Folded Horn Subwoofer System 4" VC Woofer
Brand:|Model: AB-36C|Part # 246-410
The new AB-36C Folded Horn subwoofer by Cerwin-Vega has up to 3,200 watts peak power, 4" voice coil, and a bass frequency extension similar to a 36" driver with even more SPL performance.
Part # 246-410
  • Newly designed 18” woofer with Stroker™ technology for increased output and reduced distortion
  • Improved power handling to 1600 watts
  • Radial cooling fins located outside the aluminum Stroker™ pole, increase cooling and improve the AB-36C’s efficiency
  • Stroker™ pole is vented out the back of the back plate for improved voice coil cooling
  • Aluminum cooling ring above voice coil gap for improved heat transfer from the voice coil, providing improved power handling and reduced compression
  • Stroker™ technology adds a third plane of suspension eliminating cone rocking and allows increased excursion while maintaining a tight gap that provides higher sensitivity
  • The six magnet sections and the tunnels located between them, provide cooling below the top plate
The AB-36C "Afterburner" is a highly advanced design that incorporates Cerwin-Vega's 50 years of experience in building some of the industry's best-known subwoofers. Its design makes it ideal for use in the most demanding environments where pure bass power is the goal, such as installations, live sound, mobile DJs, and club applications. The AB-36C features Stroker™ Technology for increased power handling, decreased distortion, and radial cooling fins. A striking die cast door has improved heat dissipation capabilities and sports a "Stroker 18" metal badge. In addition, the curved horn mouth bracing provides a smoother frequency response and the enhanced front corner bracing offers extra durability.
Its rugged cast aluminum C-Series door functions as a heat sink Stroker™ technology for increased power handling, decreased distortion, and radial cooling fins. Rounded horn mouth creates smoother frequency response Steel front corner bracing to improve cabinet strength Redesigned durable Multi-ply construction An extra-deep, reinforced pole cup that keeps pole-mounted speakers stable. Integrated wheels and a new Cerwin-Vega! ergonomic handle for easier transportability. Optimized for use with all Cerwin-Vega! full range top cabinets to create dedicated system solutions.
Power capacity
800 watts RMS, 1,600 watts program, 3,200 watts peak
Frequency response-3 dB, 40 Hz - 310 Hz/ -10 dB, 33 Hz - 350 Hz
Input connectors
1/4" phono, Speakon
Recommended power
1,200 watts - 1,600 watts @ 8 ohms
Sensitivity (1w/1m)
108 dB
Nominal impedance
8 ohms
Dimensions
36" x 24" x 36"
Weight
156.3 lbs.
  • ConfigurationSubwoofer
  • Woofer Size18"
  • BrandCerwin-Vega
  • ModelAB-36C
  • Part Number246-410
  • UPC743658901144
  • Weight180 lbs.
View similar products to the Cerwin-Vega AB-36C Stroker 18" Folded Horn Subwoofer System 4" VC Woofer
