Celestion TF1530 15" Professional Speaker 400W
Brand:|Model: TF1530|Part # 294-2092
Celestion's TF1530 15" speaker will produce excellent results in PA sound system applications that demand a reliable, extremely efficient, and good sounding low frequency or midrange driver.
List Price$195.00
You Save49%
Part # 294-2092
  • High output 15" bass and midrange driver
  • Efficient magnet assembly enables 99 dB sensitivity and 400 watts RMS power handling
  • 3" high temperature copper voice coil wound on polyimide for increased reliability
  • Double half-roll surround for greater excursion control
  • Superb price/performance ratio
The Celestion TF1530 15" pro speaker features a strong, non-resonant stamped steel frame, 3" copper voice coil, and powerful 86 oz. ceramic ferrite magnet. This combination results in rugged durability, high power handling, and extreme efficiency. The TF1530 will perform superbly as the bass component in 2-way PA loudspeakers, as well as deliver superior reproduction when deployed as a midrange device in large-scale sound reinforcement systems.
  • Nominal Diameter15"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance8 ohms
  • Frequency Response40 to 3,000 Hz
  • Sensitivity99 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Magnet Weight86 oz.
  • Resonant Frequency (Fs)45 Hz
  • DC Resistance (Re)5.7 ohms
  • Voice Coil Inductance (Le)1.08 mH
  • Mechanical Q (Qms)4.2
  • Electromagnetic Q (Qes)0.42
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)4.99 ft.³
  • Mechanical Compliance of Suspension (Cms)0.14 mm/N
  • BL Product (BL)18.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)3.24g
  • Moving Mass Of Diaphragm (Mmd)2.74
  • Maximum Linear Excursion (Xmax)2 mm
  • Cone MaterialPaper / Glass Fiber
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.16"
  • Baffle Cutout Diameter13.86"
  • Depth6.42"
  • # Mounting Holes8
  • Sealed Volume1.5 ft.³
  • Sealed F392 Hz
  • Vented Volume3.67 ft.³
  • Vented F351 Hz
  • BrandCelestion
  • ModelTF1530
  • Part Number294-2092
  • UPC739894529853
  • Weight17.95 lbs.
View similar products to the Celestion TF1530 15" Professional Speaker 400W
