Celestion TF1225e 12" Professional Speaker 300W
Brand:|Model: TF1225e|Part # 294-2080
Celestion's TF1225e 12" pro speaker features a flatwound copper 2.5" voice, the use of which increases efficiency and power handling.
List Price$142.00
You Save33%
$94.99
Part # 294-2080
  • 12" bass and midrange driver with extended low frequency response
  • 2.5" edgewound copper voice coil provides 96 dB sensitivity and 300 watts power handling
  • Kevlar-loaded cone with sealed, damped double half-roll surround for reduced distortion
  • Vented pole piece reduces voice coil operating temperatures
  • Suitable for use in 2-way and compact 3-way systems
The Celestion TF1225e's flatwound voice coil improves its critical power handling and efficiency specifications. Copper ribbon wire is wound on a polyimide former, and the resulting improvement in electromagnetic qualities guarantees higher output, better thermal transfer, and extended high frequency response. The TF1225e will produce extended, high impact bass and superb midrange definition when used in professional sound reinforcement and stage monitor loudspeaker systems.
  • Nominal Diameter12"
  • Power Handling (RMS)300 Watts
  • Power Handling (max)600 Watts
  • Impedance8 ohms
  • Frequency Response50 to 3,000 Hz
  • Sensitivity96 dB 2.83V/1m
  • Voice Coil Diameter2.5"
  • Magnet Weight50 oz.
  • Resonant Frequency (Fs)61.2 Hz
  • DC Resistance (Re)5.07 ohms
  • Voice Coil Inductance (Le)1.1 mH
  • Mechanical Q (Qms)4.8
  • Electromagnetic Q (Qes)0.44
  • Total Q (Qts)0.4
  • Compliance Equivalent Volume (Vas)1.79 ft.³
  • Mechanical Compliance of Suspension (Cms)0.13 mm/N
  • BL Product (BL)15.41 Tm
  • Diaphragm Mass Inc. Airload (Mms)53.24g
  • Moving Mass Of Diaphragm (Mmd)46.31
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Cone MaterialPaper / Kevlar
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.17"
  • Baffle Cutout Diameter11.14"
  • Depth5.47"
  • # Mounting Holes4
  • Sealed Volume0.59 ft.³
  • Sealed F3121 Hz
  • Vented Volume1.45 ft.³
  • Vented F365 Hz
  • BrandCelestion
  • ModelTF1225e
  • Part Number294-2080
  • UPC739894532358
  • Weight10.95 lbs.
