Celestion TF1218 12" Professional Speaker 100W
Brand:|Model: TF1218|Part # 294-2072
Offering Celestion's legendary performance at an entry-level price, the Celestion TF1218 12" pro speaker gives great results when used as a woofer component in 2-way PA loudspeaker systems.
List Price$97.00
You Save33%
$64.99
Part # 294-2072
  • 12" bass and midrange driver offering a superior price/performance ratio
  • Provides 97dB sensitivity and 100 watts RMS power handling
  • 1.75" high temperature copper voice coil wound on a polyimide former for increased reliability
  • Kevlar-loaded cone with damped, sealed surround reduces distortion
  • Suitable for use in 2-way systems
The Celestion TF1218 12" woofer/midrange driver features a strong stamped steel frame, powerful 31 oz. ceramic ferrite magnet, and 1.75" high temperature copper voice coil wound on a polyimide former. The TF1218's frequency response is smooth and extended, which supports a wide range of possible crossover points when used in 2-way speaker systems.
  • Nominal Diameter10"
  • Power Handling (RMS)100 Watts
  • Power Handling (max)200 Watts
  • Impedance8 ohms
  • Frequency Response60 to 4,500 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter1.75"
  • Magnet Weight31 oz.
  • Resonant Frequency (Fs)62 Hz
  • DC Resistance (Re)5.55 ohms
  • Voice Coil Inductance (Le)0.57 mH
  • Mechanical Q (Qms)4.9
  • Electromagnetic Q (Qes)0.72
  • Total Q (Qts)0.63
  • Compliance Equivalent Volume (Vas)2.35 ft.³
  • Mechanical Compliance of Suspension (Cms)0.17 mm/N
  • BL Product (BL)10.9 Tm
  • Diaphragm Mass Inc. Airload (Mms)39.41g
  • Moving Mass Of Diaphragm (Mmd)32.5
  • Maximum Linear Excursion (Xmax)2 mm
  • Cone MaterialPaper / Kevlar
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.17"
  • Baffle Cutout Diameter11.14"
  • Depth4.92"
  • # Mounting Holes4
  • Sealed Volume3.47 ft.³
  • Sealed F379 Hz
  • Vented Volume5.87 ft.³
  • Vented F341 Hz
  • BrandCelestion
  • ModelTF1218
  • Part Number294-2072
  • UPC739894527958
  • Weight7.2 lbs.
View similar products to the Celestion TF1218 12" Professional Speaker 100W
I am looking at building an enclosure for 2 x Celestion TF1218 speakers for acoustic guitar amp. I am unsure whether to go with a fully enclosed cabinet or not. My main question is regarding the size of the cabinet. Is it as simple as doubling the size.
Asked by: Marty Step
Yes, if you double the number of woofers you simply double the volume of the cabinet.
Date published: 2015-06-15
  • 2016-02-06T07:44CST
  • loc_en_US, sid_294-2072, PRD, sort_recentQuestionsFirst
