Celestion NTR21-5010JD 21" Neodymium Subwoofer 8 Ohm
Brand:|Model: NTR21-5010JD|Part # 294-2042
For live sound low frequency reproduction, Celestion's 21" NTR21-5010JD can't be beat! The high output and power handling, low distortion design is second to none.
List Price$824.00
You Save33%
$549.00
Part # 294-2042
  • 5" diameter inside/outside wound voice coil
  • Extensively vented neodymium motor
  • High power handling and high output
  • 9 mm of Xmax and double suspension for extra long excursion
Celestion's NTR21-5010JD 21" subwoofer features an advanced neodymium-powered motor for maximum output without maximum weight. To keep control of the driver when used with high power amplifiers (of up to 1,600 watts RMS), Celestion employs double suspension and a multi-roll surround for exceptional linearity during extreme excursion moments that are common with lower frequency reproduction. A lightweight carbon fiber-loaded paper cone is used due to its rigidity and ability to respond quickly to audio impulses.
Intelligent heat management is designed into the cast aluminum chassis, high temperature 5" inside/outside wound voice coil, and extensively vented neodymium magnet which prevents thermal compression and the resulting loss and sensitivity. Last, but certainly not least, this 21" subwoofer has an amazing 9 mm of Xmax to move massive amounts of air.
  • Nominal Diameter21"
  • Power Handling (RMS)1,600 Watts
  • Power Handling (max)3200 Watts
  • Impedance8 ohms
  • Frequency Response30 to 3,000 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter5"
  • Resonant Frequency (Fs)30.2 Hz
  • DC Resistance (Re)5.36 ohms
  • Voice Coil Inductance (Le)2.06 mH
  • Mechanical Q (Qms)5.23
  • Electromagnetic Q (Qes)0.31
  • Total Q (Qts)0.29
  • Compliance Equivalent Volume (Vas)12.05 ft.³
  • Maximum Linear Excursion (Xmax)9 mm
  • Cone MaterialCarbon Fiber Composite
  • Surround MaterialCloth
  • Magnet MaterialNeodymium
  • Overall Outside Diameter21.65"
  • Baffle Cutout Diameter19.37"
  • Depth10"
  • # Mounting Holes8
  • Sealed Volume1.78 ft.³
  • Sealed F382 Hz
  • Vented Volume3.55 ft.³
  • Vented F352 Hz
  • BrandCelestion
  • ModelNTR21-5010JD
  • Part Number294-2042
  • UPC739894576307
  • Weight37.5 lbs.
RCF L15S801 15" Woofer Speaker
Part #  294-864
RCF L15/554K 15" Woofer Speaker
Part #  294-866
View similar products to the Celestion NTR21-5010JD 21" Neodymium Subwoofer 8 Ohm
