Celestion G12M Greenback 12" 8 Ohm Guitar Speaker 25W
Brand:|Model: G12M Greenback|Part # 294-2262
The G12M Greenback 8 ohm version exhibits all the classic G12M characteristics but is voiced with additional broad mid-range attack and restrained top-end to give a forward, punchy attitude to chords and a searing lead tone without fizz.
List Price$185.00
You Save32%
Part # 294-2262
Celestion's first guitar loudspeaker featuring a ceramic magnet structure, the G12M 'Greenback' presented almost as much magnetic flux to the voice coil as an Alnico formulation, but in a much more compact space. As a result the Greenback became the guitar loudspeaker that paved the way for use with higher power amplifiers. And, of course, the ceramic magnet presented its own unique tonal characteristics.
The Greenback has a loud and assertive character that sounds great through a valve amp pushed into overdrive. The speaker has evolved over the decades and still presents that instantly familiar woody tone, delivered with a knockout punch. With its well-controlled low-end it can be used singly in low-powered amps, or in multiples for high-power rock heads. It’s an ideal speaker to bring drive and definition to modern high gain amps.
Overall Specifications: • Nominal diameter: 12" (305 mm) • Power rating: 25 watts • Nominal impedance: 8 ohm • Sensitivity: 98 dB • Chassis type: Pressed steel • VCdia: 1.75" (44.5 mm) • Voice coil material: Round copper • Magnet type: Ceramic • Frequency range: 75-5,000 Hz • Fs: 75 Hz • DC resistance, Re: 6.7 ohm.
Mounting Information: • Diameter: 12.2" (309 mm) • Overall depth: 5.1" (130 mm) • Magnet structure diameter: 5.9" (150 mm) • Cut-out diameter: 11.1" (283 mm) • Mounting slot dimensions: 0.31" (7.9 mm Ø) • Number of mounting slots: 4 • Mounting slot PCD: 11.7" (297 mm) • Weight: 7.9 lbs. (3.6 kg).
  • TypeLead / Rhythm Guitar
  • Nominal Diameter12"
  • Impedance8 ohms
  • Power Handling (RMS)25 Watts
  • Magnet MaterialCeramic Ferrite
  • BrandCelestion
  • ModelG12M Greenback
  • Part Number294-2262
  • UPC739894122054
  • Product CategoryGuitar Speakers & Bass Guitar Speakers
    (1 Reviews)
  • Weight9.8 lbs.
View similar products to the Celestion G12M Greenback 12" 8 Ohm Guitar Speaker 25W
in the Guitar Speakers & Bass Guitar Speakers product category.
