Celestion FTR18-4080F 18" Professional Cast Frame Speaker 600W
Brand:|Model: FTR18-4080F|Part # 294-2012
Celestion's FTR18-4080F 18" speaker will deliver great performance in pro subwoofer enclosures of all types, including bandpass, direct radiator, and horn loaded.
List Price$300.00
You Save33%
Part # 294-2012
  • Well-vented ceramic ferrite magnetic assembly, 600 watts RMS power handling, and 97 dB sensitivity
  • 4" high temperature Inside/Outside voice coil efficiently dissipates heat, preventing sensitivity loss through thermal compression
  • Flexirol™ surround for greater excursion control
  • Low frequency response, down to 30 Hz, for deep sub-bass response
  • Smart chassis design minimizes acoustic distortion
  • Specially treated weather-resistant cone guarantees long service life
The cast frame Celestion FTR18-4080F 18" pro woofer employs the same great technology and construction as its sibling speakers, but at a lower price point. The FTR18-4080F's 110 oz. ceramic ferrite magnet, Inside/Outside 4" voice coil, and advanced thermal management work in combination to make this one of the best bang-for-the-buck professional drivers, period.
  • Nominal Diameter18"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance8 ohms
  • Frequency Response30 to 3,000 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Magnet Weight110 oz.
  • Resonant Frequency (Fs)32 Hz
  • DC Resistance (Re)5.31 ohms
  • Voice Coil Inductance (Le)1.46 mH
  • Mechanical Q (Qms)5.24
  • Electromagnetic Q (Qes)0.32
  • Total Q (Qts)0.3
  • Compliance Equivalent Volume (Vas)9.6 ft.³
  • Mechanical Compliance of Suspension (Cms)0.15 mm/N
  • BL Product (BL)23.31 Tm
  • Diaphragm Mass Inc. Airload (Mms)5.58g
  • Moving Mass Of Diaphragm (Mmd)4.82
  • Maximum Linear Excursion (Xmax)6 mm
  • Cone MaterialPaper / Glass Fiber
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.19"
  • Baffle Cutout Diameter16.38"
  • Depth8.07"
  • # Mounting Holes8
  • Sealed Volume1.53 ft.³
  • Sealed F385 Hz
  • Vented Volume3.05 ft.³
  • Vented F354 Hz
  • BrandCelestion
  • ModelFTR18-4080F
  • Part Number294-2012
  • UPC739894546157
    (2 Reviews)
  • Weight27.3 lbs.
View similar products to the Celestion FTR18-4080F 18" Professional Cast Frame Speaker 600W
