Celestion FTR15-4080HDX 15" Professional Cast Frame Speaker 1000W
Brand:|Model: FTR15-4080HDX|Part # 294-2010
A 1" long x 4" diameter voice coil, thermally-optimized ceramic magnet assembly, and dual spiders contribute to the Celestion FTR15-4080HDX 15" pro woofer's impressive performance capabilities.
Ships in 7-10 Business Days
List Price$375.00
You Save33%
Part # 294-2010
  • 1,000 watts RMS power handling and a frequency response of 40 Hz-2500 Hz
  • 4" high temperature Inside/Outside voice coil efficiently dissipates heat, preventing sensitivity loss through thermal compression
  • Double suspension and a "multi-roll" surround provide exceptional linearity at extremes of cone excursion
  • Intelligent heat management in both chassis and magnet assembly design further minimizes distortion
  • Just over 25 lbs. – very low weight for this product class
The Celestion FTR15-4080HDX 15" woofer is an extreme-duty woofer intended for the most demanding pro audio applications. It features a 1" long by 4" diameter copper wire Inside/Outside voice coil; by winding the layers on both sides of the fiberglass former, greater stability under thermal stress is achieved. The die cast aluminum chassis supports a massive, high-BL 110 oz. ceramic ferrite motor structure, and the dual spider design and multi-roll cone termination ensure maximum control.
  • Nominal Diameter15"
  • Power Handling (RMS)1,000 Watts
  • Power Handling (max)2000 Watts
  • Impedance8 ohms
  • Frequency Response40 to 2,500 Hz
  • Sensitivity96 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Magnet Weight110 oz.
  • Resonant Frequency (Fs)40 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)1.8 mH
  • Mechanical Q (Qms)3.98
  • Electromagnetic Q (Qes)0.36
  • Total Q (Qts)0.33
  • Compliance Equivalent Volume (Vas)3.68 ft.³
  • Mechanical Compliance of Suspension (Cms)0.1 mm/N
  • BL Product (BL)23.53 Tm
  • Diaphragm Mass Inc. Airload (Mms)5.42g
  • Moving Mass Of Diaphragm (Mmd)4.92
  • Maximum Linear Excursion (Xmax)8 mm
  • Cone MaterialPaper / Glass Fiber
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.16"
  • Baffle Cutout Diameter13.82"
  • Depth7.1"
  • # Mounting Holes8
  • Sealed Volume0.73 ft.³
  • Sealed F397 Hz
  • Vented Volume1.53 ft.³
  • Vented F359 Hz
  • BrandCelestion
  • ModelFTR15-4080HDX
  • Part Number294-2010
  • UPC739894561150
  • Weight25 lbs.
RCF L15/554K 15" Woofer Speaker
Part #  294-866
RCF L15S801 15" Woofer Speaker
Part #  294-864
View similar products to the Celestion FTR15-4080HDX 15" Professional Cast Frame Speaker 1000W
