Celestion FTR15-4080F 15" Professional Cast Frame Speaker 600W
Brand:|Model: FTR15-4080F|Part # 294-2006
Celestion's FTR15-4080F 15" pro speaker makes great use of its 4" diameter x 7/8" long Inside/Outside voice coil and large magnet to achieve excellent efficiency, a high BL factor, great reliability, and low thermally-induced power compression.
List Price$270.00
You Save33%
Part # 294-2006
  • High-BL (23.69 Tm) 15" woofer with 110 oz. ferrite magnet boasts 600 watts RMS power handling and 97 dB sensitivity
  • 4" high temperature Inside/Outside voice coil efficiently dissipates heat, preventing sensitivity loss through thermal compression
  • Flexirol™ surround for greater excursion control
  • Low frequency response, down to 35 Hz
  • Smart chassis design minimizes acoustic distortion
  • Specially treated weather-resistant cone
A workhorse 15" pro woofer, the Celestion FTR15-4080F utilizes a large 4" diameter voice coil and massive 110 oz. ceramic ferrite magnet to generate class-leading motor strength. Extensive attention has been paid to thermal management, and Celestion's experienced engineers incorporated multiple ventilation paths to cool the motor assembly and achieve top performance. The FTR15-4080F's 22 mm long voice coil winding helps it achieve a 10 mm Xmax rating, which helps to explain the driver's prodigious bass output and low distortion. Parameters have been optimized to provide excellent results in pro audio enclosures of all types.
  • Nominal Diameter15"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance8 ohms
  • Frequency Response35 to 3,000 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Magnet Weight110 oz.
  • Resonant Frequency (Fs)35 Hz
  • DC Resistance (Re)5.62 ohms
  • Voice Coil Inductance (Le)1.48 mH
  • Mechanical Q (Qms)3.68
  • Electromagnetic Q (Qes)0.26
  • Total Q (Qts)0.24
  • Compliance Equivalent Volume (Vas)6.45 ft.³
  • Mechanical Compliance of Suspension (Cms)0.18 mm/N
  • BL Product (BL)23.69 Tm
  • Diaphragm Mass Inc. Airload (Mms)4.16g
  • Moving Mass Of Diaphragm (Mmd)3.66
  • Maximum Linear Excursion (Xmax)6 mm
  • Cone MaterialPaper / Glass Fiber
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.16"
  • Baffle Cutout Diameter13.82"
  • Depth6.69"
  • # Mounting Holes8
  • Sealed Volume0.63 ft.³
  • Sealed F3115 Hz
  • Vented Volume1.21 ft.³
  • Vented F374 Hz
  • BrandCelestion
  • ModelFTR15-4080F
  • Part Number294-2006
  • UPC739894545853
  • Weight25.2 lbs.
View similar products to the Celestion FTR15-4080F 15" Professional Cast Frame Speaker 600W
