Celestion FTR15-3070C 15" Professional Cast Frame Speaker 400W
Brand:|Model: FTR15-3070C|Part # 294-2004
Celestion has used its vast experience to minimize the effects of power compression on the FTR15-3070C 15" speaker, while at the same time achieving high efficiency and extremely low distortion.
List Price$240.00
You Save33%
Part # 294-2004
  • Features 400 watts RMS power handling and 99 dB sensitivity
  • 3" high temperature Inside/Outside voice coil efficiently dissipates heat, preventing sensitivity loss
  • Flexirol™ surround for greater excursion control
  • Saturated gap technology for lower harmonic distortion
  • Low frequency response, down to 40 Hz
  • Smart chassis design minimizes acoustic distortion
The Celestion FTR15-3070C 15" pro speaker combines high efficiency with smooth response, backed up by superb reliability. Celestion's expert engineering ensures every operating parameter has been completely optimized, which guarantees faultless performance -- even under the stressful conditions found in pro audio environments. The FTR15-3070C features an Inside/Outside voice coil that is wound on a nearly indestructible fiberglass former. Winding the coil on both sides of the former ensures the stress of thermal expansion is canceled by the opposing masses of copper wire. Accurate and durable, the FTR15-3070C will provide excellent service in direct radiator and horn-loaded applications.
  • Nominal Diameter15"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance8 ohms
  • Frequency Response40 to 4,000 Hz
  • Sensitivity99 dB 1W/1m
  • Voice Coil Diameter3"
  • Magnet Weight81 oz.
  • Resonant Frequency (Fs)40 Hz
  • DC Resistance (Re)6.5 ohms
  • Voice Coil Inductance (Le)0.59 mH
  • Mechanical Q (Qms)7.1
  • Electromagnetic Q (Qes)0.38
  • Total Q (Qts)0.36
  • Compliance Equivalent Volume (Vas)7.34 ft.³
  • BL Product (BL)18.7 Tm
  • Moving Mass Of Diaphragm (Mmd)2.47
  • Maximum Linear Excursion (Xmax)10 mm
  • Cone MaterialPaper / Glass Fiber
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.16"
  • Baffle Cutout Diameter13.82"
  • Depth6.22"
  • # Mounting Holes8
  • Sealed Volume1.79 ft.³
  • Sealed F389 Hz
  • Vented Volume4.11 ft.³
  • Vented F351 Hz
  • BrandCelestion
  • ModelFTR15-3070C
  • Part Number294-2004
  • UPC739894538756
  • Weight17.25 lbs.
Pyle PBW10S 10" Midbass
Part #  292-2528
B&C 12NW76 12" Neodymium Woofer
Part #  294-681
RCF L15P540 15" Woofer Speaker
Part #  294-860
View similar products to the Celestion FTR15-3070C 15" Professional Cast Frame Speaker 400W
