Celestion FTR12-4080HDX 12" Professional Cast Frame Speaker 1000W
Brand:|Model: FTR12-4080HDX|Part # 294-2002
With 1000 watts RMS (AES standard) power handling and a frequency response of 47 Hz-3 kHz, the Celestion FTR12-4080HDX is a brilliantly designed and expertly built pro audio 12" woofer.
ORDER TODAY
Ships in 3-10 business days
List Price$300.00
You Save33%
$199.99
Part # 294-2002
  • Cast aluminum frame supports a powerful ceramic ferrite magnet assembly
  • 12" ferrite woofer/subwoofer provides 1,000 watts RMS power handling
  • 4" high temperature Inside/Outside voice coil efficiently dissipates heat and prevents sensitivity loss
  • Double suspension and a "multi-roll" surround provide exceptional linearity
  • Intelligent heat management further minimizes distortion
The Celestion FTR12-4080HDX 12" woofer/subwoofer features an advanced thermal management system that includes the use of an Inside/Outside voice coil and careful attention to motor ventilation. This system results in reduced power compression caused by increased resistance due to heat build-up; the result is greater reliability and the speaker's ability to maintain maximum SPL during extended hard use. The FTR12-4080HDX's dual-spider design and multi-roll outer suspension combine maximum excursion with ultimate control, resulting in deep, powerful, low-distortion bass output.
  • Nominal Diameter12"
  • Power Handling (RMS)1,000 Watts
  • Power Handling (max)2000 Watts
  • Impedance8 ohms
  • Frequency Response47 to 3,000 Hz
  • Sensitivity93 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Magnet Weight110 oz.
  • Resonant Frequency (Fs)61 Hz
  • DC Resistance (Re)6.05 ohms
  • Voice Coil Inductance (Le)1.92 mH
  • Mechanical Q (Qms)2.23
  • Electromagnetic Q (Qes)0.45
  • Total Q (Qts)0.37
  • Compliance Equivalent Volume (Vas)0.88 ft.³
  • Mechanical Compliance of Suspension (Cms)0.06 mm/N
  • BL Product (BL)23.81 Tm
  • Diaphragm Mass Inc. Airload (Mms)3.8g
  • Moving Mass Of Diaphragm (Mmd)3.59
  • Maximum Linear Excursion (Xmax)8 mm
  • Cone MaterialPaper / Glass Fiber
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.3"
  • Baffle Cutout Diameter11.1"
  • Depth6.2"
  • # Mounting Holes8
  • Sealed Volume0.24 ft.³
  • Sealed F3130 Hz
  • Vented Volume0.56 ft.³
  • Vented F373 Hz
  • BrandCelestion
  • ModelFTR12-4080HDX
  • Part Number294-2002
  • UPC739894560757
  • Weight24.35 lbs.
View similar products to the Celestion FTR12-4080HDX 12" Professional Cast Frame Speaker 1000W
