Celestion FTR12-3070C 12" Professional Cast Frame Speaker 350W
Brand:|Model: FTR12-3070C|Part # 294-2000
Celestion's FTR12-3070C 12" mid/bass driver features a powerful ceramic ferrite magnet, die cast aluminum chassis, and 3" voice coil. It will provide outstanding results in sealed, vented, or horn-loaded enclosures.
List Price$195.00
You Save33%
$129.99
Part # 294-2000
  • Ferrite magnet aluminum chassis driver
  • Low frequency response down to 40 Hz
  • Intelligent heat management in both chassis and magnet assembly design minimizes distortion
  • Specially treated weather-resistant cone for added long-term durability
  • Great performance as a woofer or midrange component in professional PA systems
The Celestion FTR12-3070C 12" ferrite mid/bass driver offers 350 watts RMS (AES standard) power handling and 96 dB sensitivity. Its 3" high temperature Inside/Outside voice coil efficiently dissipates heat, which increases reliability and prevents sensitivity loss due to thermal compression. The FTR12-3070C features smooth response in the critical vocal midrange frequencies, while still providing plenty of clean, solid bass.
  • Nominal Diameter12"
  • Power Handling (RMS)350 Watts
  • Power Handling (max)700 Watts
  • Impedance8 ohms
  • Frequency Response40 to 4,000 Hz
  • Sensitivity96 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Magnet Weight81 oz.
  • Resonant Frequency (Fs)66 Hz
  • DC Resistance (Re)5.44 ohms
  • Voice Coil Inductance (Le)1.25 mH
  • Mechanical Q (Qms)2.9
  • Electromagnetic Q (Qes)0.38
  • Total Q (Qts)0.33
  • Compliance Equivalent Volume (Vas)1.4 ft.³
  • Mechanical Compliance of Suspension (Cms)0.1 mm/N
  • BL Product (BL)18.78 Tm
  • Diaphragm Mass Inc. Airload (Mms)58.51g
  • Maximum Linear Excursion (Xmax)3 mm
  • Cone MaterialPaper / Glass Fiber
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.5"
  • Baffle Cutout Diameter11.26"
  • Depth5.1875"
  • # Mounting Holes8
  • Sealed Volume0.29 ft.³
  • Sealed F3157 Hz
  • Vented Volume0.62 ft.³
  • Vented F394 Hz
  • BrandCelestion
  • ModelFTR12-3070C
  • Part Number294-2000
  • UPC739894564458
  • Weight16 lbs.
B&C 15HPL76 15" Neodymium Woofer
Part #  294-682
B&C 15PS100 15" Woofer
Part #  294-673
View similar products to the Celestion FTR12-3070C 12" Professional Cast Frame Speaker 350W
