Celestion Classic Lead 80 12" 16 Ohm Guitar Speaker 80W
Brand:|Model: Classic Lead 80|Part # 294-2280
The Classic Lead 16 ohm speaker by Celestion is much-loved by lead guitarists for its speed, punch and articulation, with every note clearly defined on even big, distorted sounds.
Ships in 7-10 Business Days
List Price$220.00
You Save32%
Part # 294-2280
Revolutionary in the late '70s, a fibreglass voice coil former - capable of withstanding very high temperatures - was used to give the Classic Lead a muscular 80 watt power handling. This also increased barrel stiffness, affecting the way the cone vibrated and influencing cone break up. Then, through experimentation with edge treatments and continued critical  listening, some modes were encouraged while others were suppressed, contributing to the speaker's unique sound.
A firm favorite with lead guitarists, the Classic Lead features a tightly controlled low-end, with strong high bass/low mid punch, aggressive mid range attack and a powerful yet controlled top-end. For power chords it has the tone to make its presence felt but the subtle high-frequency roll-off makes it ideal for solos, able to project single notes on loud stages without becoming shrill.
Overall Specifications: • Nominal diameter: 12" (305 mm) • Power rating: 80 watts • Nominal impedance: 16 ohm • Sensitivity: 99 dB • Chassis type: Pressed steel • VCdia: 1.75" (44.5 mm) • Voice coil material: Round copper • Magnet type: Ceramic • Frequency range: 80-5,000 Hz • Fs: 85 Hz • DC resistance, Re: 11.8 ohm.
Mounting Information: • Diameter: 12.2" (309 mm) • Overall depth: 5.3" (135 mm) • Magnet structure diameter: 6.1" (156 mm) • Cut-out diameter: 11.1" (283 mm) • Mounting slot dimensions: 0.31" (7.9 mm Ø) • Number of mounting slots: 4 • Mounting slot PCD: 11.7" (297 mm) • Weight: 10.4 lbs. (4.7 kg).
  • TypeLead / Rhythm Guitar
  • Nominal Diameter12"
  • Impedance16 ohms
  • Power Handling (RMS)80 Watts
  • Magnet MaterialCeramic Ferrite
  • BrandCelestion
  • ModelClassic Lead 80
  • Part Number294-2280
  • UPC739894397858
  • Product CategoryGuitar Speakers & Bass Guitar Speakers
  • Weight12 lbs.
View similar products to the Celestion Classic Lead 80 12" 16 Ohm Guitar Speaker 80W
in the Guitar Speakers & Bass Guitar Speakers product category.
