Celestion CF18VJD 18" Professional Subwoofer 1600W
Brand:|Model: CF18VJD|Part # 294-2100
For the best in live sound low frequency reproduction, Celestion's 18" CF18VJD can't be beat! Low distortion is ensured by the use of dual demodulation rings in the motor, double suspension, and extreme ventilation used throughout.
List Price$880.00
You Save47%
Part # 294-2100
  • FEA optimized motor for symmetrical flux and cone movement
  • Dual demodulation rings for reduced electromagnetic distortion
  • 5" inside/outside wound voice coil and 9 mm of Xmax
  • Extensively vented driver design
Celestion's CF18VJD 18" subwoofer features an advanced, FEA optimized motor for maximum output and symmetrical cone movement, which results in low harmonic distortion, as well as two demodulation rings for low electromagnetic distortion.
To keep control of the driver when used with high power amplifiers (of up to 1,600 watts RMS), Celestion employs double suspension and a multi-roll surround for exceptional linearity during extreme excursion moments that are common with lower frequency reproduction. A lightweight carbon fiber and Kevlar-loaded paper cone is used due to its rigidity and ability to respond quickly to audio impulses.
Intelligent heat management is designed into the cast aluminum chassis, high temperature 5" inside/outside wound voice coil, and extensively vented ferrite magnet which prevents thermal compression and the resulting loss and sensitivity. Last, but certainly not least, this 18" subwoofer has an amazing 9 mm of Xmax to move massive amounts of air.
For more information on this subwoofer, check out Celestion's BUILD THIS! project featuring the CF18VJD.
  • Nominal Diameter18"
  • Power Handling (RMS)1,600 Watts
  • Power Handling (max)3200 Watts
  • Impedance8 ohms
  • Frequency Response25 to 1,500 Hz
  • Sensitivity97 dB 1W/1m
  • Voice Coil Diameter5"
  • Resonant Frequency (Fs)33.1 Hz
  • DC Resistance (Re)5.51 ohms
  • Voice Coil Inductance (Le)1.99 mH
  • Mechanical Q (Qms)9.64
  • Electromagnetic Q (Qes)0.32
  • Total Q (Qts)0.31
  • Compliance Equivalent Volume (Vas)5.79 ft.³
  • Maximum Linear Excursion (Xmax)9 mm
  • Cone MaterialCarbon Fiber / Kevlar
  • Surround MaterialCloth
  • Overall Outside Diameter18.19"
  • Baffle Cutout Diameter16.38"
  • Depth9.17"
  • Sealed Volume0.98 ft.³
  • Sealed F385 Hz
  • Vented Volume1.96 ft.³
  • Vented F353 Hz
  • BrandCelestion
  • ModelCF18VJD
  • Part Number294-2100
  • UPC739894580656
    (1 Reviews)
  • Weight50.4 lbs.
View similar products to the Celestion CF18VJD 18" Professional Subwoofer 1600W
