Celestion CDX20-3000 Neo 2" Compression Horn Driver 75W
Brand:|Model: CDX20-3000|Part # 294-2152
For the widest possible range that extends from a low midrange crossover point to sparkling HF, a 2" large format compression driver is the one to beat. The Celestion CDX20-3000 may be one of the best of the best!
Ships in 7-10 Business Days
List Price$600.00
You Save33%
Part # 294-2152
  • 2" exit, neodymium magnet, 3" voice coil compression driver provides 75 watts RMS power handling and 107 dB sensitivity
  • Patented phase plug design method suppresses cavity resonances at higher frequencies
  • Titanium diaphragm, deep drawn to increase stiffness and reduce distortion
  • Lower compression ratio reduces air non-linearity and allows for higher maximum SPL
  • Rolled polyimide surround improves stiffness control, further lowering distortion
  • Curved coherent wavefront, optimized for horn loading
The Celestion CDX20-3000 2" high frequency driver employs an optimized neodymium magnet system in conjunction with a brilliantly executed 3" diameter voice coil and titanium diaphragm. These carefully coordinated sub-components work in harmony to enable this device to achieve impressive performance specifications, like very high efficiency, extremely low distortion, and extended frequency response.
Specifications: • Power handling: 75 watts RMS (AES standard) • Recommended min. crossover: 800 kHz, 12 dB/octave • VCdia: 3" • Impedance: 8 ohms • Frequency range: 500-18,000 Hz • Sensitivity: 107 dB 1W/1m • Mounting (flange): 4 x M6 holes on 4" PCD • Dimensions: 5" dia. x 3.7" depth • Net weight: 4.4 lbs.
  • Mounting Type4-Bolt
  • Exit Diameter2"
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)75 Watts
  • BrandCelestion
  • ModelCDX20-3000
  • Part Number294-2152
  • UPC739894568340
  • Product CategoryHorn Drivers
  • Weight4.55 lbs.
View similar products to the Celestion CDX20-3000 Neo 2" Compression Horn Driver 75W
in the Horn Drivers product category.
