Celestion CDX14-3050 Neo 1.4" Compression Horn Driver 75W
Brand:|Model: CDX14-3050|Part # 294-2148
The 1.4" format Celestion CDX1-3050 neodymium HF driver is a high output, low distortion option for professional sound reinforcement loudspeaker systems.
Ships in 7-10 Business Days
List Price$540.00
You Save33%
Part # 294-2148
  • 1.4" exit, neodymium magnet, 3" voice coil compression driver provides 75 watts RMS power handling and 106.5 dB sensitivity
  • Patented phase plug design method suppresses cavity resonances at higher frequencies
  • Titanium diaphragm, deep drawn to increase stiffness and reduce distortion
  • Lower compression ratio reduces air non-linearity and allows for higher maximum SPL
  • Rolled polyimide surround improves stiffness control, further lowering distortion
  • Curved coherent wavefront, optimized for horn loading
The Celestion CDX14-3050 Neo 1.4" medium format high frequency device utilizes a 3" diameter voice coil to drive a specially profiled titanium diaphragm. The fully optimized phase plug and neodymium magnetic circuit guarantee a perfect balance is struck between extended range, efficiency, and low distortion.
Specifications: • Power handling: 75 watts RMS (AES standard) • Recommended min. crossover: 1,000 kHz, 12 dB/octave • VCdia: 3" • Impedance: 8 ohms • Frequency range: 500-18,000 Hz • Sensitivity: 106.5 dB 1W/1m • Mounting (flange): 4 x M6 holes on 4" PCD • Dimensions: 5" dia. x 2.2" depth • Net weight: 3.7 lbs.
  • Mounting Type4-Bolt
  • Exit Diameter1.4"
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)75 Watts
  • BrandCelestion
  • ModelCDX14-3050
  • Part Number294-2148
  • UPC739894564045
  • Product CategoryHorn Drivers
  • Weight3.75 lbs.
View similar products to the Celestion CDX14-3050 Neo 1.4" Compression Horn Driver 75W
in the Horn Drivers product category.
