Celestion CDX1-1746 Ferrite 1" Compression Driver 75W
Brand:|Model: CDX1-1746|Part # 294-2128
The Celestion CDX1-1746 1" HF driver provides a screw-on version of their high-output, low distortion compression driver family.
ORDER TODAY
Ships in 3-10 business days
List Price$120.00
You Save33%
$79.99
Part # 294-2128
  • 1" exit, ferrite magnet compression driver with 1.75" edgewound copper-clad aluminum voice coil
  • 75 watts power handling and 110 dB sensitivity
  • Sound Castle™ clamping ensures even pressure on diaphragm assembly for reduced distortion
  • One-piece PETP diaphragm and surround for durability and uncolored sound reproduction
  • Finite Element Analysis (FEA) used to optimize both magnet assembly and acoustic design
The Celestion CDX1-1746 1" HF driver uses FEA optimization on its moving parts as well as its magnetic circuit. The result is extreme efficiency, high power handling, and very low distortion. The CDX1-1746 is capable of delivering stunningly clear, hi-fi quality output, but at the explosive sound reinforcement levels demanded of pro loudspeaker systems. Also available in a 1" bolt-on version, the CDX1-1745.
Specifications: • Power handling: 75 watts RMS (AES standard) • Recommended min. crossover: 2,200 kHz, 12 dB/octave • VCdia: 1.75" • Impedance: 8 ohms • Frequency range: 1,200-20,000 Hz • Sensitivity: 110 dB 1W/1m • Mounting: Screw-on, standard 1-3/8"-18 TPI • Dimensions: 4.7" dia. x 2.2" depth • Net weight: 5.1 lbs.
  • Mounting Type1-3/8"-18 TPI
  • Exit Diameter1"
  • Diaphragm MaterialPoly / Mylar
  • Impedance8 ohms
  • Power Handling (RMS)75 Watts
  • BrandCelestion
  • ModelCDX1-1746
  • Part Number294-2128
  • UPC739894548748
  • Product CategoryHorn Drivers
  • Weight5 lbs.
View similar products to the Celestion CDX1-1746 Ferrite 1" Compression Driver 75W
in the Horn Drivers product category.
