294-2140_ALT_0
294-2140_ALT_1
Celestion CDX1-1730 Neo 1" Compression Horn Driver 75W
Brand:| Model: CDX1-1730
Celestion's top-performing 1" high frequency driver, the CDX1-1730 benefits from a powerful neodymium motor and a breakthrough PETP film diaphragm -- both of which were optimized via FEA tools.
  • 1" exit, neodymium magnet compression driver with 1.75" edgewound copper clad aluminum voice coil
  • 75 watts RMS power handling and 110 dB sensitivity
  • Designed with Sound Castleā„¢ clamping to ensure uniform pressure on diaphragm assembly for reduced acoustic distortion
  • One piece PETP film diaphragm and surround for accurate, non-fatiguing reproduction
  • Advanced Finite Element Analysis (FEA) tools used to create a very light weight, high powered compression driver
294-2140
Weight: 1.55 lbs.
OUT OF STOCK
Due In: 8/15/2014
List Price$194.99
You Save33%
$129.99
Part # 294-2140
The Celestion CDX1-1730 is engineered and produced to very high standards, and its power handling and efficiency are competitive with much larger format 1.4" and 2" drivers. CDX1-1730 transducers are ideally suited to compact, high-output professional 2-way speaker systems, as well as excelling in the role of tweeter in extreme SPL 3-way loudspeakers.
Specifications: • Power handling: 75 watts RMS (AES standard) • Recommended min. crossover: 2,200 kHz, 12 dB/octave • VCdia: 1.75" • Impedance: 8 ohms • Frequency range: 1,200-20,000 Hz • Sensitivity: 110 dB 1W/1m • Mounting (flange): 4 x M6 holes on 3" PCD • Dimensions: 3.48" dia. x 2.2" depth • Net weight: 1.4 lbs.
  • Mounting Type4-Bolt
  • Exit Diameter1"
  • Diaphragm MaterialPoly / Mylar
  • Impedance8 ohms
  • Power Handling (RMS)75 Watts
  • BrandCelestion
  • ModelCDX1-1730
  • Part Number294-2140
  • UPC739894548540
  • Product CategoryHorn Drivers
  • Weight1.55 lbs.
View similar products to the Celestion CDX1-1730 Neo 1" Compression Horn Driver 75W
in the Horn Drivers product category.
Celestion CDX1-1730 Neo 1" Compression Horn Driver 75W is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Revived my Behringer B512ADue to lack of response from Behringer, I looked elsewhere for replacement drivers. Chose these merely because the port size and hole pattern suggested they would fit.Installation was no problem, and those B512A's sound far better than they ever did with Behringer drivers.
Date published: 2013-05-24
Customer projects that include: Celestion CDX1-1730 Neo 1" Compression Horn Driver 75W
