Celestion CDX1-1730 1" 40 Watt Neodymium Compression Driver 8 Ohm
Brand:|Model: CDX1-1730|Part # 294-2140
Celestion's top-performing 1" high frequency driver, the CDX1-1730 benefits from a powerful neodymium motor and a breakthrough PETP film diaphragm -- both of which were optimized via FEA tools.
List Price$210.00
You Save33%
$139.99
Part # 294-2140
  • 1" exit, neodymium magnet compression driver with 1.75" edgewound copper clad aluminum voice coil
  • 40 watts RMS power handling and 110 dB sensitivity
  • Designed with Sound Castle™ clamping to ensure uniform pressure on diaphragm assembly for reduced acoustic distortion
  • One piece PETP film diaphragm and surround for accurate, non-fatiguing reproduction
  • Advanced Finite Element Analysis (FEA) tools used to create a very light weight, high powered compression driver
The Celestion CDX1-1730 is engineered and produced to very high standards, and its power handling and efficiency are competitive with much larger format 1.4" and 2" drivers. CDX1-1730 transducers are ideally suited to compact, high-output professional 2-way speaker systems, as well as excelling in the role of tweeter in extreme SPL 3-way loudspeakers.
Specifications: • Power handling: 40 watts RMS (AES standard) • Recommended min. crossover: 2,200 kHz, 12 dB/octave • VCdia: 1.75" • Impedance: 8 ohms • Frequency range: 1,200-20,000 Hz • Sensitivity: 110 dB 1W/1m • Mounting (flange): 4 x M6 holes on 3" PCD • Dimensions: 3.48" dia. x 2.2" depth • Net weight: 1.4 lbs.
  • Mounting Type4-Bolt
  • Exit Diameter1"
  • Diaphragm MaterialPoly / Mylar
  • Impedance8 ohms
  • Power Handling (RMS)40 Watts
  • BrandCelestion
  • ModelCDX1-1730
  • Part Number294-2140
  • UPC739894548540
  • Product CategoryHorn Drivers
    (1 Reviews)
  • Weight1.55 lbs.
View similar products to the Celestion CDX1-1730 1" 40 Watt Neodymium Compression Driver 8 Ohm
in the Horn Drivers product category.
