Celestion CDX1-1430 Neo 1" Compression Horn Driver 50W
Brand:|Model: CDX1-1430|Part # 294-2136
The Celestion CDX1-1430 1" high frequency driver's very good power handling capacity and extreme efficiency are far more than what you would expect from a transducer of this size.
List Price$172.00
You Save33%
$114.99
Part # 294-2136
  • 1" exit neodymium compression driver with 1.4" copper clad aluminum voice coil
  • 50 watts RMS power handling and 108 dB sensitivity
  • Copper sleeve on pole reduces inductive rise for improved HF performance
  • Ferrofluid in magnet gap prevents sensitivity loss through thermal compression
  • Aluminum diaphragm combined with elastomer surround delivers lower distortion performance
  • Finite Element Analysis (FEA) used to optimize both magnet and acoustic design
Celestion's experience and high-tech engineering have produced the CDX1-1430, a small yet efficient neodymium HF driver. It is perfect for applications that require excellent fidelity and high output, but must achieve it in limited cabinet space. Line arrays and compact 2-way and 3-way loudspeaker systems benefit from the CDX1-1430's very favorable performance/size ratio.
Specifications: • Power handling: 50 watts RMS (AES standard) • Recommended min. crossover: 2,500 kHz, 12 dB/octave • VCdia: 1.4" • Impedance: 8 ohms • Frequency range: 2,000-20,000 Hz • Sensitivity: 108 dB 1W/1m • Mounting (flange): 2 x M6 holes on 3" PCD • Dimensions: 3.5" dia. x 2.3" depth • Net weight: 1 lbs.
  • Mounting Type2-Bolt
  • Exit Diameter1"
  • Diaphragm MaterialAluminum
  • Impedance8 ohms
  • Power Handling (RMS)50 Watts
  • BrandCelestion
  • ModelCDX1-1430
  • Part Number294-2136
  • UPC739894536752
  • Product CategoryHorn Drivers
  • Weight1.1500 lbs.
View similar products to the Celestion CDX1-1430 Neo 1" Compression Horn Driver 50W
in the Horn Drivers product category.
