Celestion CDX1-1425 Neo 1" Compression Horn Driver 25W
Brand:|Model: CDX1-1425|Part # 294-2132
Celestion high frequency drivers are a popular OEM component -- many loudspeaker system manufacturers are incorporating transducers like the CDX1-1425 into their designs.
List Price$150.00
You Save33%
Part # 294-2132
  • 1" exit neodymium compression driver with 1.4" copper clad aluminum voice coil
  • 25 watts RMS power handling and 108 dB sensitivity
  • Copper sleeve on pole reduces inductive rise for improved HF performance
  • Ferrofluid in magnet gap prevents sensitivity loss through thermal compression
  • Aluminum diaphragm combined with elastomer surround delivers lower distortion performance
  • Finite Element Analysis (FEA) used to optimize both magnet and acoustic design
  • Suitable for 2-way and 3-way systems, and line arrays
The Celestion CDX1-1425 is a leading example of the emerging class of ultra-compact neodymium high frequency drivers. The CDX1-1425's minimal size makes it ideal for the spacing constraints of professional line array systems as well as very small 2-way and 3-way loudspeakers.
Specifications: • Power handling: 25 watts RMS (AES standard) • Recommended min. crossover: 2,500 kHz, 12 dB/octave • VCdia: 1.4" • Impedance: 8 ohms • Frequency range: 2,000-20,000 Hz • Sensitivity: 108 dB 1W/1m • Mounting (flange): 2 x M6 holes on 3" PCD • Dimensions: 3.5" dia. x 2.3" depth • Net weight: 0.9 lbs.
  • Mounting Type2-Bolt
  • Exit Diameter1"
  • Diaphragm MaterialAluminum
  • Impedance8 ohms
  • Power Handling (RMS)25 Watts
  • BrandCelestion
  • ModelCDX1-1425
  • Part Number294-2132
  • UPC739894534444
  • Product CategoryHorn Drivers
  • Weight1 lbs.
View similar products to the Celestion CDX1-1425 Neo 1" Compression Horn Driver 25W
in the Horn Drivers product category.
