Celestion CDX1-1415 Neo 1" Compression Horn Driver 20W
Brand:|Model: CDX1-1415|Part # 294-2130
The incredibly small Celestion CDX1-1415 1" HF transducer is a perfect example of how tiny a well-engineered neodymium compression driver can be!
ORDER TODAY
Ships in 7-10 Business Days
List Price$135.00
You Save33%
$89.99
Part # 294-2130
  • 1" exit neodymium compression driver with 1.4" copper clad aluminum voice coil
  • 20 watts RMS power handling and 104 dB sensitivity
  • Copper sleeve on pole reduces inductive rise for improved HF performance
  • Ferrofluid in magnet gap prevents sensitivity loss through thermal compression
  • Aluminum diaphragm combined with elastomer surround delivers lower distortion performance
  • Compact magnet design reduces weight and minimizes stray flux
  • Suitable for 2-way and 3-way systems
The Celestion CDX1-1415 HF driver uses a neodymium motor structure and the company's vast design experience to great effect. Despite its small size, the CDX1-1415 provides all the smooth, clear high frequency output a pro audio loudspeaker system could need.
Specifications: • Power handling: 20 watts RMS (AES standard) • Recommended min. crossover: 2,500 kHz, 12 dB/octave • VCdia: 1.4" • Impedance: 8 ohms • Frequency range: 2,000-20,000 Hz • Sensitivity: 104 dB 1W/1m • Mounting (flange): 2 x M6 holes on 3" PCD • Dimensions: 3.5" dia. x 2.2" depth • Net weight: 0.6 lbs.
  • Mounting Type2-Bolt
  • Exit Diameter1"
  • Diaphragm MaterialAluminum
  • Impedance8 ohms
  • Power Handling (RMS)20 Watts
  • BrandCelestion
  • ModelCDX1-1415
  • Part Number294-2130
  • UPC739894534352
  • Product CategoryHorn Drivers
  • Weight0.65 lbs.
View similar products to the Celestion CDX1-1415 Neo 1" Compression Horn Driver 20W
in the Horn Drivers product category.
