Celestion BL15-400X 15" 8 Ohm Bass Guitar Speaker 400W
Brand:|Model: BL15-400X|Part # 294-2460
Celestion's BL15-400X 8 ohm 15" bass driver, from the Green Label Series, is built for high-power rock performances, where a full-bodied, warm, and defined tone is essential.
List Price$194.99
You Save33%
$129.99
Part # 294-2460
  • Bumped back plate prevents voice coil from bottoming out
  • 400 Watts RMS and 96dB efficiency for high output with little effort
  • Extended low frequency response for improved bottom end thump
Not every player wants a super-clean, high-fidelity bass sound. Characterized by an extended low end and greater linear excursion, Green Label speakers push out every note with a rich, warm tone and a powerful low-end thump.
Green Label speakers are primed for high-powered rock performances, where a full-bodied, warm, defined tone is essential.
Overall Specifications: • Nominal diameter: 15" (381 mm) • Power rating: 400 watts • Nominal impedance: 8 ohm • Sensitivity: 96 dB • VCdia: 3" (76.2 mm) • Voice coil material: Copper • Magnet type: Ferrite • Frequency range: 40-3,500 Hz • Fs: 54.2 Hz • DC resistance, Re: 5.8 ohm.
Mounting Information: • Diameter: 15.2" (385 mm) • Overall depth: 6.4" (162 mm) • Cut-out diameter: 13.8" (351 mm) • Mounting slot dimensions: 0.36 x 0.24" (9.2 x 6.2 mm) • Number of mounting slots: 8 • Mounting slot PCD: 14.5" (369 mm) • Weight: 10.8 lbs. (4.9 kg).
  • TypeBass Guitar
  • Nominal Diameter15"
  • Impedance8 ohms
  • Power Handling (RMS)400 Watts
  • Magnet MaterialCeramic Ferrite
  • BrandCelestion
  • ModelBL15-400X
  • Part Number294-2460
  • UPC739894562751
  • Product CategoryGuitar Speakers & Bass Guitar Speakers
  • Weight16.5 lbs.
View similar products to the Celestion BL15-400X 15" 8 Ohm Bass Guitar Speaker 400W
in the Guitar Speakers & Bass Guitar Speakers product category.
