Celestion 18" Cast Frame Professional Woofer 8 Ohm
Brand:|Part # 299-420
Live sound audio professionals and HiFi home audio enthusiasts will both enjoy this steal of a deal! This Celestion 18" cast frame woofer features an advanced motor design, a Kevlar-loaded paper cone, and 5.5 mm of Xmax! All of this, for nearly half the price of similar drivers. Factory buyout!
Comparable Items In Stock:
  • 97 dB sensitivity makes it great for high output 3-way speakers
  • Non-pressed, Kevlar-loaded paper cone
  • 5.5 mm of Xmax for subwoofer duty
  • Cast aluminum frame for robust durability
  • Save over half off similarly priced speakers
This cast aluminum frame 18" OEM bass driver from Celestion was designed in Great Britain for use in high-end bass speakers. The motor features extensive ventilation, a bumped backplate for reduced voice coil "bottoming out" conditions, and a vented pole piece for minimum power compression. A non-pressed, Kevlar-loaded paper cone is mated to a treated cloth accordion surround for increased sensitivity without sacrificing durability. Nickel-plated, spring-loaded terminals provide a quick, sure connection.
A relatively flat frequency response up to 3,000 Hz makes this driver well suited for use as a woofer in high output three-way HiFi home audio systems, and easy to cross over to a midrange. Additionally, the 97 dB sensitivity of this driver allows it to be used for professional audio, live sound three-way speakers; great for DJs too! 5.5 mm of Xmax are on tap to make this driver a great subwoofer! Factory buyout, limited quantities! Compares to speakers at twice the price!
Note: For best bass response, install this 18" woofer into a 10.5 cubic foot cabinet tuned to 38 Hz with two 6" diameter ports that are 4.25" long. Alternatively, you can also use a smaller 7.5 cubic foot cabinet tuned to 45 Hz with two 6" diameter ports that are 4.5" long.
  • Nominal Diameter18"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1,000 Watts
  • Impedance8 ohms
  • Frequency Response35 to 3,500 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)46.9 Hz
  • DC Resistance (Re)6.08 ohms
  • Mechanical Q (Qms)2.84
  • Electromagnetic Q (Qes)0.60
  • Total Q (Qts)0.50
  • Compliance Equivalent Volume (Vas)9.57 ft.³
  • BL Product (BL)17.13 Tm
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Cone MaterialPaper / Kevlar
  • Surround MaterialCloth
  • Overall Outside Diameter17.83"
  • Baffle Cutout Diameter16.38"
  • Depth7.76"
  • Sealed Volume3.59 ft.³
  • Sealed F376 Hz
  • Vented Volume9.75 ft.³
  • Vented F338 Hz
  • BrandFactory Buyouts
  • Part Number299-420
  • UPC848864000695
  • Weight16.65 lbs.
View similar products to the Celestion 18" Cast Frame Professional Woofer 8 Ohm
