CE Labs CAT5TX Component Cat 5 HD Transmitter
Brand:|Model: CAT5TX|Part # 180-027
The CE Labs CAT5TX Component Cat 5 HD transmitter uses Cat 5 wire to distribute high definition component or composite video and digital or left and right audio over extended distances.
OUT OF STOCK
Awaiting Updated Due Date
List Price$159.90
You Save45%
$88.49
Part # 180-027
  • Active amplification ensures high quality transmission
  • Loop output for use of additional Cat 5 transmitters
  • Second Cat 5 output for additional location
  • Discrete passive IR channel for the use of external IR remote control systems
The CE Labs CAT5TX Component Cat 5 HD transmitter uses Cat 5 wire to distribute high definition component or composite video and digital or left and right audio over extended distances. Use with CE Labs' CAT5RX receiver, sold separately. NOTE: Composite video may be used for security or with standard monitors.
• Power supply (included): External 9 VAC @ 600 mA with (2.1 mm center) coaxial connector • Dimensions: 6.9" x 3.3" x 1.3".
Video:
•Nominal input level: 1 volt peak to peak
•Gain: 1 volt into 75 ohms (2 volts unterminated)
•Input impedance (CAT5TX): 75 ohms
•Output impedance (CAT5RX): 75 ohms
•Isolation port to port: >65 dB
•Isolation output to input: >80 dB
•Return loss: >20 dB
•Video bandwidth: >50 MHz (HDTV requires 37 MHz minimum)
•Distance: >500 ft. @ 1080i (1,000 ft. with Cat 6 cable)
•Three composite video signals may be substituted on the individual component video inputs (1,000 ft. max.)
 Audio:
•Gain: Unity (slightly reduced at max cable length)
•Input impedance: 22K ohms
•Output impedance: 1K ohms
•Frequency response: 20 Hz to 20 KHz
•Signal to noise: 80 dB @ 1 volt out
•Digital audio: Supports standard SPDIF digital audio
  • Audio Input/OutputL/R Analog,Digital Coaxial
  • Video Input/OutputComponent
  • BrandCE Labs
  • ModelCAT5TX
  • Part Number180-027
  • UPC617190002112
  • Product CategoryAudio / Video Distribution
  • Weight1.7 lbs.
View similar products to the CE Labs CAT5TX Component Cat 5 HD Transmitter
in the Audio / Video Distribution product category.
Is there a package that contains 1 Transmitter and 2 Receivers?
Asked by: mwilliam84
We do carry the CAT5RX receiver unit, but we do not have a bundle or package with more than one transmitter or receiver at this time.
Answered by: RussR
Date published: 2012-04-11
  • 2016-02-10T07:54CST
  • loc_en_US, sid_180-027, PRD, sort_recentQuestionsFirst
