CE Labs CAT5RX Component Cat 5 HD Receiver
Brand:|Model: CAT5RX|Part # 180-026
Using Cat 5 wire, the CE Labs CAT5RX Component Cat 5 HD Receiver distributes high definition component or composite video and digital or left and right audio over extended distances.
  • Cable length equalizer for long distances
  • Video continuity LEDs to ensure all signals are transmitting
  • IR port
Using Cat 5 wire, the CE Labs CAT5RX Component Cat 5 HD Receiver distributes high definition component or composite video and digital or left and right audio over extended distances. Use with the CE Labs CAT5TX transmitter, sold separately. NOTE: Composite video may be used for security or with standard monitors.
• Power supply (included): External 9 VAC @ 600 mA with (2.1 mm center) coaxial connector • Dimensions: 6.9" x 3.3" x 1.3".
Video:
•Nominal input level: 1 volt peak to peak
•Gain: 1 volt into 75 ohms (2 volts unterminated)
•Input impedance (CAT5TX): 75 ohms
•Output impedance (CAT5RX): 75 ohms
•Isolation port to port: >65 dB
•Isolation output to input: >80 dB
•Return loss: >20 dB
•Video bandwidth: >50 MHz (HDTV requires 37 MHz minimum)
•Distance: >500 ft. @ 1080i (1,000 ft. with Cat 6 cable)
•Three composite video signals may be substituted on the individual component video inputs (1,000 ft. max.)
Audio:
•Gain: Unity (slightly reduced at max cable length)
•Input impedance: 22k ohms
•Output impedance: 1k ohms
•Frequency response: 20 Hz to 20 kHz
•Signal to noise: 80 dB @ 1 volt out
•Digital audio: Supports standard S/PDIF digital audio
  • Audio Input/OutputL/R Analog,Digital Coaxial
  • Video Input/OutputComponent
  • BrandCE Labs
  • ModelCAT5RX
  • Part Number180-026
  • UPC617190200129
  • Product CategoryAudio / Video Distribution
  • Weight1.7 lbs.
View similar products to the CE Labs CAT5RX Component Cat 5 HD Receiver
in the Audio / Video Distribution product category.
