CE Labs C5T6 Component Cat 5 Transmitter/Receiver Hub
Brand:|Model: C5T6|Part # 180-024
CE Labs' C5T6 Component Cat 5 Transmitter/Receiver Hub distributes high definition component or composite video and digital or left and right audio over extended distances using Cat 5 wire.
  • Six output HD Component + audio Cat 5 distribution
  • Loop output for use of additional Cat 5 transmitters
  • Six Cat 5 outputs for additional locations
  • Discrete passive IR channel for the use of external IR remote control systems
  • Balanced or unbalanced inputs for maximum versatility
CE Labs' C5T6 Component Cat 5 Transmitter/Receiver Hub distributes high definition component or composite video and digital or left and right audio over extended distances using Cat 5 wire. Video & audio loop output to accommodate future expansion to additional Cat 5 transmitters & receivers. Active amplification ensures high quality transmission. Note: Each remote location will require two CATX cables. *Power: External 9 or 10 VAC @ 1200 mA (2.1 mm center) with a coaxial barrel connector (power supply is included) *Dimensions: 19" x 3.5" x 1.4" *Weight: 4.8 lbs.
Video (all channels including Component and Cat 5):
•Nominal input level: 1 volt peak to peak
•Gain: 1 volt into 75 ohms (2 volts unterminated)
•Input impedance: 75 ohms Component, 100 ohms twisted pair input
•Output impedance: 75 ohms loop out, 100 ohms twisted pair output
•Isolation port to port: >45 dB
•Isolation output to input: >65 dB
•Return loss: >20 dB
•Video bandwidth: >75 MHz
•Distance: Maximum distance varies between 400 ft. to 500 ft. depending upon the type of cable used, type of receiver, and video resolution
•Three composite video signals may be substituted on the individual component video inputs (1,000 ft. max.)
Audio:
•Gain: Unity (slightly reduced at max. cable length)
•Input impedance: 22k ohm Audio IN
•100 ohms twisted pair IN
•Output impedance: 1k ohm on Loop Out, 100 ohms twisted pair Out
•Frequency response: 20 Hz to 100 kHz
•Signal to noise: 80 dB @ 1 volt Out
Digital Audio:
•Supports standard SPDIF digital audio. Unity gain when terminated into 75 ohms. (composite video is supported on this port.)
  • Audio Input/OutputL/R Analog,Digital Coaxial
  • Video Input/OutputComponent
  • BrandCE Labs
  • ModelC5T6
  • Part Number180-024
  • UPC617190002518
  • Product CategoryAudio / Video Distribution
  • Weight4.8 lbs.
View similar products to the CE Labs C5T6 Component Cat 5 Transmitter/Receiver Hub
in the Audio / Video Distribution product category.
