CE Labs AV901HD HDTV A/V Distribution Amp 9-Out
Brand:|Model: AV901HD|Part # 180-005
The AV901HD is a high quality HDTV and analog video distribution amp that also distributes digital or analog audio. The unit can distribute A/V signals up to nine locations (up to 150 ft.) and has the ability to be daisy chained to other units, allowing for unending expandability.
List Price$319.90
You Save41%
$188.90
Part # 180-005
  • 1 input and 9 outputs
  • Distribute A/V to 9 different locations without any signal loss
  • Compatible with all HDTV, digital, and analog video signals
  • Allows up to 150-ft runs
The AV901HD is a high quality HDTV and analog video distribution amp that also distributes digital or analog audio. The unit can distribute A/V signals up to nine locations (up to 150 ft.) and has the ability to be daisy chained to other units, allowing for unending expandability. Save time and money by using the AV901HD for distribution rather than expensive A/V receivers. If the digital audio port is not used it can be switched to be used with standard composite video. Power supply is included.
Specifications: Video: • Gain: 2V un-terminated, 1V terminated: 75 ohms + 5% • Input impedance: 75 ohms + 5% • Output impedance: 75 ohms + 5% • Video insertion loss: 50 Hz to 10 MHz < 0.40 dB • In to out isolation: 50 Hz to 10 MHz 32 dB port to port • Out to in isolation: 50 Hz to 10 MHz 60 dB • Return loss: 50 Hz to 10 MHz 20 dB • Video bandwidth: > 100 MHz • Audio response: > 100 KHz Audio: • Gain: Unity • Input impedance: 22k ohm • Output impedance: 1k ohm • THD: 0.05% at 1V input level • Frequency response: 20 Hz to 100 KHz • Channel separation: > 75 dB @ 1 KHz • In to out isolation: 60 dB • Out to out isolation: 60 dB • Signal to noise: 100 dB re 2V(out) • Supports standard SPDIF digital audio • Unity gain when terminated into 75 ohms (2X gain high imp.) • Greater than 50 MHz of bandwidth to ensure minimal degradation. Power: • Requirement: External 9 to 10 Volt AC @ 1000 mA with a 2.1 mm coaxial connector • Power supply is included.
  • Audio Input/OutputL/R Analog,Digital Coaxial
  • Video Input/OutputComposite,Component
  • BrandCE Labs
  • ModelAV901HD
  • Part Number180-005
  • UPC617190001122
  • Product CategoryAudio / Video Distribution
  • Weight4.1001 lbs.
View similar products to the CE Labs AV901HD HDTV A/V Distribution Amp 9-Out
in the Audio / Video Distribution product category.
