180-004_ALT_0
CE Labs AV501HDX HDTV A/V Distribution Amp 5-Out
Brand:|Model: AV501HDX|Part # 180-004
The AV501HDX is a high quality HDTV and analog video distribution amp that also distributes digital or analog audio. The unit can distribute A/V signals up to five locations (up to 150 ft.) and has the ability to be daisy chained to other units, allowing for unending expandability.
- Order Soon - Only 3 Left In Stock
List Price$271.90
You Save53%
$127.90
Part # 180-004
  • 1 input and 5 outputs
  • Delivers A/V to 5 different locations without any signal loss
  • Compatible with all HDTV, digital & analog video signals
  • Allows up to 150 ft. runs
The AV501HDX is a high quality HDTV and analog video distribution amp that also distributes digital or analog audio. The unit can distribute A/V signals up to five locations (up to 150 ft.) and has the ability to be daisy chained to other units, allowing for unending expandability. Save time and money by using the AV501HDX for distribution rather than expensive A/V receivers. If the digital audio port is not used it can be switched to be used with standard composite video. Power supply is included.
Specifications: • Video: Gain: 2V un-terminated, 1V terminated: 75 ohms + 5% • Input impedance: 75 ohms + 5% • Output impedance: 75 ohms + 5% • Video insertion loss: 50 Hz to 10 MHz, less than .40 dB • In to out isolation: 50 Hz to 10 MHz 32 dB port to port • Out to in isolation: 50 Hz to 10 MHz 60 dB •Return loss: 50 Hz to 10 MHz 20 dB         • Video bandwidth: greater than 100 MHz • Audio response: greater than 100 kHz. Audio: Gain: Unity • Input impedance: 22k ohm • Output impedance: 1k ohm • THD: 0.05% at 1V input level • Frequency response: 20 Hz to 100 KHz • Channel separation: greater than 75 dB @ 1 KHz • In to out isolation: 60 dB • Out to out isolation: 60 dB • Signal to noise: greater than 100 dB • Supports standard SPDIF digital audio • Unity gain when terminated into 75 ohms (2X gain high imp.). • Greater than 50 MHz of bandwidth to ensure minimal degradation. Power: Requirement: External 9 to 10V AC @ 500 mA with a 2.1 mm coaxial connector • Power supply is included.
  • Audio Input/OutputL/R Analog,Digital Coaxial
  • Video Input/OutputComposite,Component
  • BrandCE Labs
  • ModelAV501HDX
  • Part Number180-004
  • UPC617190002150
  • Product CategoryAudio / Video Distribution
    (4 Reviews)
  • Weight3.3001 lbs.
View similar products to the CE Labs AV501HDX HDTV A/V Distribution Amp 5-Out
in the Audio / Video Distribution product category.
