Cast Frame #8-32 Speaker Mounting Kit
Heavy duty mounting kit for cast frame drivers. It features black anodized 1-1/2" long #8-32 machine screws.
260-779
Weight: 0.1 lbs.
IN STOCK
List Price$4.99
You Save32%
$3.39
Buy 10-up$2.87
Part # 260-779
Heavy duty mounting kit for cast frame drivers. It features black anodized 1-1/2" long #8-32 machine screws. The hex drive cap screws will not damage the front gasket and also provide a professional finishing touch to your installation. Great for tweeters or compact full range drivers. Each kit includes eight screws and eight spiked T-nuts.
Minimum cabinet baffle thickness between 3/4" to 1-1/2".
  • BrandParts Express
  • Part Number260-779
  • UPC844632082382
  • Product CategorySpeaker Mounting Kits
    (1 Reviews)
  • Weight0.1 lbs.
View similar products to the Cast Frame #8-32 Speaker Mounting Kit
in the Speaker Mounting Kits product category.
Cast Frame #8-32 Speaker Mounting Kit is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Work as advertised, beware when using 3/4" boardSo far I've built two set of speakers, using a total of 5 sets of these. Bolts go through seamlessly through he nut. Placing the nut firmly into the pre-drilled hole is the key for  success using them. If the nut is not firmly attached to the board, then the torque coming from the adjusting bolt will release the nut and the bolt will not hold whatever you are trying to attach. One issue only is that the bolts are not intended for 3/4" board, as the threads will end before the bolt goes through. A little extra torque from your drill will force the thread in the flat part of the bolt. Not a recommended practice, but in my case the bolts seem to be of slightly less hard material than the nut, so the bolt went though anyway.
Date published: 2013-11-25
What are the sizes of the screws in mm?
Asked by: GavinC
The head of the screw is 6.6mm in diameter, the shaft diameter is 4mm, total length including head is 41.8mm and the thread length is 29mm.
Date published: 2013-11-11
Fit for Amp plate ?
Hi,like to know were this fit right for Dayton Audio SPA500 Subwoofer Plate mounting hole?Item no:300-807
Asked by: woodknight
Unfortunately these are too large to fit our plate amp mounting holes.
Date published: 2012-12-13
What size hex key is needed for these? None of my key set seem to fit them.
Asked by: The Kid Slak
A 9/64" hex bit fits them perfectly. A 3.5mm bit would most likely do the trick as well.
Answered by: RussR
Date published: 2011-08-08
Customer projects that include: Cast Frame #8-32 Speaker Mounting Kit
