Cast Frame #10-32 Speaker Mounting Kit
Get that professional look with these black anodized hex head cap screws. The perfect mounting head for aluminum cast frame speakers. Large enough to secure the frame yet small enough to not deform paper and cork gaskets.
260-776
Weight: 0.4 lbs.
IN STOCK
List Price$4.99
You Save28%
$3.59
Buy 10-up$2.97
Part # 260-776
Qty:  PK
Get that professional look with these black anodized hex head cap screws. The perfect mounting head for aluminum cast frame speakers. Large enough to secure the frame yet small enough to not deform paper and cork gaskets. Kit includes eight 5/32" allen head, 1-1/2" thread length cap screws with 10-32 threads and eight self piercing spiked "T" nuts. Works well with up to 1" cabinet thickness. 5/32" allen wrench required for installation is not included.
  • BrandParts Express
  • Part Number260-776
  • UPC844632038280
  • Product CategorySpeaker Mounting Kits
  • Unit of MeasurePK
    (21 Reviews)
  • Weight0.4 lbs.
View similar products to the Cast Frame #10-32 Speaker Mounting Kit
in the Speaker Mounting Kits product category.
Cast Frame #10-32 Speaker Mounting Kit is rated 3.8571 out of 5 by 21.
Rated 5 out of 5 by from Worked PerfectlyReplaced the speaker in an old Fender Sidekick 15" bass cab and these were a perfect match.
Date published: 2014-05-02
Rated 3 out of 5 by from I agree with previous reviewer: use glueI wish I had read the reviews before trying to use these. I found that the bolts are just slightly too big in diameter, like by the thickness of the anodized coating, and they cause the bolt to catch with enough pressure to pull the t-nut teeth out (of MDF, in my case) if you go too fast. Cement the bolts in as the other poster suggested or else use very, very little torque on your screwdriver when driving the bolts. Or, purely conjecture, maybe pre-mating the bolt and nut would strip enough of the anodizing (anodizement?) off the bolt to make it not catch.
Date published: 2013-09-14
Rated 1 out of 5 by from poorjust like the rest of the comments. pretty much ruined my box.
Date published: 2013-08-07
Rated 1 out of 5 by from Great Way To Ruin A BoxThese are great if you want to ruin your box. They're very effective at stripping MDF and getting cross threaded. It's especially nice when you use these once your box is all glued together, because then you have to ditch the entire box. I highly recommend them if you like wasting time and money.
Date published: 2013-02-16
Rated 5 out of 5 by from Nice FinishLooks Great !!! First quality. You cant go wrong...
Date published: 2012-10-09
Rated 5 out of 5 by from Just used hex capsHex caps works excellent. Size is perfect. I have 1" hex caps but the 1.5" is better to work with when mounting and unmounting the driver in the enclosure.I used H-nuts instead of T-Nuts. But for H-Nuts make sure to use a good quality Super Glue; otherwise will get loose.
Date published: 2011-09-26
minimum baffle thickness?
going to use 1/2 inch mdf mounting 8 inch dvc woofer (below) are these too long/big for that?
Asked by: Dave B
The length of the unthreaded shaft is 1/4" so these will work fine for your application.
Date published: 2013-04-01
What 's the diameter of a "10"?
Is a 10 larger than 1/4"?(I'm looking for a hex head to fit the 5.5mm holes specified by Dayton for the RSS315HF-4).(Interesting that the HO version of this driver specifies 6.5mm holes.)Thanks!
Asked by: TShifrin
A #10 is smaller than a 1/4"screw. In terms of dimensions, the head diameter of these is just under 8 mm, while the shaft diameter is about 4.5 mm. On a baffle, I often drill holes larger than 4.5 mm. Then I use a 6 mm (inner diameter) washer that allows for play in the larger hole, while still covering it.
Answered by: The Kid Slak
Date published: 2011-11-10
Customer projects that include: Cast Frame #10-32 Speaker Mounting Kit
