Cascade TG-1(5G) Thermaguard Heat Shield Compound 5 Gal
Brand:|Model: TG-1(5G)|Part # 268-234
ThermaGuard is a premixed thermal insulating composite coating consisting of 80% microscopic air filled glass beads. Two standard coats (15 mil each) will yield an R20 equivalent insulation value.
Part # 268-234
ThermaGuard is a premixed thermal insulating composite coating consisting of 80% microscopic air filled glass beads. These precisely manufactured beads are held in suspension by a high-grade latex emulsion. This combination yields a lightweight, pliable product, which expands and contracts with the surface to which it is applied. Two standard coats (15 mil each) will yield an R20 equivalent insulation value. It's suitable for just about any insulating application. Typical applications include vehicle firewalls, floors and roofs, engine compartments, AC ducting and walls. Basically anywhere you would want to insulate from heat or cold TG-1 can be used. Using a 5-mil application, one gallon will cover approximately 50~60 sq. ft. and is easily applied with Cascade Audio's SG-1 spray gun. Five gallon container.
  • BrandCascade Audio
  • ModelTG-1(5G)
  • Part Number268-234
  • UPC078254021225
  • Product CategorySound Damping
  • Weight45 lbs.
View similar products to the Cascade TG-1(5G) Thermaguard Heat Shield Compound 5 Gal
in the Sound Damping product category.
