Carol 12 AWG 2C SJ Power Cable 250 ft.
This heavy duty power cable is very flexible making it suitable for a variety of uses. From high power speaker cables on a professional sound stage, to replacing the cords on small appliances, the applications for this wire are unlimited.
100-568
Weight: 30.45 lbs.
IN STOCK
$226.64
Buy 4-up$210.45
Part # 100-568
Qty:  RL
This heavy duty power cable is very flexible making it suitable for a variety of uses. From high power speaker cables on a professional sound stage, to replacing the cords on small appliances, the applications for this wire are unlimited. Premium grade black rubber jacket allows good flexibility even in low temperatures. Temperature range: -40° C to +60° C. Voltage rating: 300 volts, type SJ. UL #62. CSA #C22.2-49 where applicable. Not suitable for use where subject to acid, grease, oil, or solvents. 2 conductor colors: black and white. 3 conductor colors: black, white and green. Made in the USA. RoHS compliant.
  • Cable Rating UL Listed
  • Wire Gauge12 AWG
  • Conductors2 Conductor
  • Jacket ColorBlack
  • Length250 ft.
  • BrandCarol Cable
  • Part Number100-568
  • UPC079407013685
  • Product CategoryAC Power Cable
  • Unit of MeasureRL
    (1 Reviews)
  • Weight30.45 lbs.
View similar products to the Carol 12 AWG 2C SJ Power Cable 250 ft.
in the AC Power Cable product category.
Carol 12 AWG 2C SJ Power Cable 250 ft. is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Tough high quality cable.I am using this cable for speaker cable powering my sub-woofers. It is higher quality than the professional speaker cables I have seen. 1. Tougher to cut. There is a clear difference between this and the Dayton brand. 2. Tighter wrapping. Makes the core more solid. 3. This stuff is wrapped 4 times. Around the core there is a thin later of plastic before the rubber coat. After that there are some paper core filler with nylon string twisted with the cores. Then a paper coat around all of it, and a finial coat of rubber. Most of the speaker cable I have used is simple 2 wrapped rubber with no filler. I highly recommend this for any pro audio, or power use.
Date published: 2010-11-06
Customer projects that include: Carol 12 AWG 2C SJ Power Cable 250 ft.
