Clearance Item
Cable TV In-line Low Pass Filter Ch 2 To 82
These low pass filters from Dayton Video are used to remove all CATV channels above the pass band, allowing insertion of locally operated channels. Perfect for removing unwanted signals on a cable line so modulated channels can be fed into the video network.
180-152
Weight: 0.11 lbs.
IN STOCK
Regular Price$14.85
You Save66%
Special Price
$5.00
Part # 180-152
  • BrandParts Express
  • Part Number180-152
  • UPC844632015120
  • Product CategoryCable TV Filters
    (5 Reviews)
  • Weight0.11 lbs.
View similar products to the Cable TV In-line Low Pass Filter Ch 2 To 82
in the Cable TV Filters product category.
Cable TV In-line Low Pass Filter Ch 2 To 82 is rated 4.4 out of 5 by 5.
Rated 5 out of 5 by from Useful deviceI bought this as I needed to have some clean channels to modulate my satellite signal to. This little device did the job perfectly.
Date published: 2014-04-01
Rated 5 out of 5 by from Works greatThanks to the other review I got my filter working, used channel 90. Works great!!!!! CCTV is crystal clear on all tv's now. Could of used some type of instructions, I had no ideas what channels worked until I read the reviews, but channel 90 is all I need, THANKS
Date published: 2009-05-16
Rated 4 out of 5 by from Fixed the problem.It took about one minute to install and it blocks out 98% of the interference that my cable company recently started transmitting. I use channels 90 and 92 for cctv and the channel 82 and up filter did the job.
Date published: 2008-12-18
Rated 4 out of 5 by from Does what it saysIt works as advertised. The roll off on this is filter is pretty gradual however so expect some attenuation below channel 82.
Date published: 2008-06-18
Rated 4 out of 5 by from works wellworked well for deleting channels above 82
Date published: 2007-11-23
Will this filter block digital channels?
Asked by: JoshSWP
This filter is designed to block all signals from your cable line above the passband. In this case, channels higher than 82 would be blocked, digital, analog, or otherwise.
Answered by: RussR
Date published: 2011-07-07
Customer projects that include: Cable TV In-line Low Pass Filter Ch 2 To 82
Manuals / Resources
Related Products
Customers Also Bought
