Cable TV In-Line Coaxial Surge Protector
Protects your expensive equipment from damage by lightning and power surges. "F" male to "F" female.
180-190
Weight: 0.0726 lbs.
IN STOCK
$4.50
Buy 10-49 $3.98
Buy 50-up$3.34
Part # 180-190
  • BrandParts Express
  • Part Number180-190
  • UPC844632011689
  • Product CategoryCable TV Filters
    (9 Reviews)
  • Weight0.0726 lbs.
View similar products to the Cable TV In-Line Coaxial Surge Protector
in the Cable TV Filters product category.
Cable TV In-Line Coaxial Surge Protector is rated 4.3333 out of 5 by 9.
Rated 5 out of 5 by from Great Value and PerformanceI recently dropped my cable TV and switched to Antenna TV. I have an attic mounted antenna with a Motorola signal booster. With the antenna and signal booster, I was concerned about lightening surge to my TVs and other video equipment. These inline coaxial surge protectors are a great value, and they cause no signal loss. I have one on the antenna and one on each of my two coaxial outlets. They work great and I have my TVs and video equipment protected. I purchased a few extras, so I have replacements right away in the event of a ligthening strike and power surge. Great product!
Date published: 2013-11-28
Rated 5 out of 5 by from Maximum service from this product; excellent!The electricity went off during a storm, and my computer went dead. With my new computer I felt impressed to purchase this product for added protection and to give me peace of mind. I am fully satisfied since I purchased this surge protector.
Rated 5 out of 5 by from Needed ProtectionHaving experienced a lightning strike that came into the house through the cable system, I can vouch for the damage it causes. Three TV's, a computer, a modem and, because the current wasn't stopped at the cable input ports, it got into the AC line. A dishwasher, a microwave, and a treadmill also required replacement. This unit would have stopped all of that, and should be used at each point cable is connected.
Rated 5 out of 5 by from Great productIt's exactly what I wanted...an in-line coax surge protector that did not require me to run the coax all the way to a traditional oversized surge protector with a coax input. Additional benefit is that this makes it easier to keep the coax cable away from power cords that cause signal degredation.
Rated 4 out of 5 by from Great valueGreat value for an in-line solution. Easy to install.
Date published: 2011-02-17
Rated 4 out of 5 by from Cleaner LookThankfully I have not had to test it out yet. I like the fact that I don't have to have extra cables running in and out of my surge strip. This definitely makes for a cleaner installation.It has not degraded the quality of my cable companys digital signal or my cable modem use.
How does this device shunt a surge with no apparent ground connection?
One would think that surge protection would require a heavy ground in order to carry the energy of the surge away from the device and the equipment it is protecting. How is protection achieved?
Asked by: Marcus1260
This device is a non-ohmic variable resistor, or varistor. Varistors do not shunt surges. This would imply redirection of the current to another path such as ground. This is not how varistors work. Normal operation of a varistor is shunt mode, whereby current bypasses the varistor and is allowed to flow through the circuit unimpeded. When input voltage is higher than the clamping voltage, i.e. a surge, the varistor's resistance increases infinitely, cutting off the flow of current. Resistance dictates current flow. When resistance is sufficiently high, current will not flow. See Ohm's law.Note that varistors degrade after each surge, and can degrade rapidly, or simply fail, after an extremely large surge, such as a lighting strike. Therefore, this is a consumable deivce. Given the low cost, for maximum continuous protection, it is a good idea to replace this device once a year if you live in the Midwest, or anywhere electrical storms are frequent. Definitely replace it immediately after a nearby lighting strike.No specs are given for this low cost unit. I'd suspect its joule rating is very low. Running 2 of them in series will double your protection. Normally I install a single large value suppressor at the inside distribution panel. With this product you'd probably want to install two to four in series at the panel for maximum protection. As it has male/female connections it is apprently designed with this in mind, else it would be double female.
Answered by: HardwareFreak
Date published: 2012-12-16
What is the RF loss?
Asked by: Racoraco
THe -Insertion Loss: Less than 0.2 dB Video-1500 MHz -Return Loss ( 75 ohm):16dB
Answered by: Chrisf
Date published: 2013-04-24
What's the frequency range?
The previous question on the loss gives an answer for loss to 1500 MHz, but other sites list this same part (including PE model) as covering 5-2300 MHz.
Asked by: Lord Beo
The specs on current stock are below:Current stock Surgender SE-1 specs- Surge Protection Attack Time:0.0000001 seconds (100 nanosec.) -Maximum Surge Current: 5000 Amps. (8 microsec x 20 microsec test pulse) -Maximum Surge Voltage:Multiply 5000 times Ohms of Coax Loop -Surge life: 200 Surges of 500 Amps. (10 microsec x 1000 microsec test pulse) -Normal Resistance Across Coax: 10,000 Mega Ohms -Surge Resistance: Approx. 0 Ohm -Power Passing Capability:50 Volts DC or AC peak-to-peak 36 Volts RMS, 10 Amps -Insertion Loss: Less than 0.2 dB Video-1500 MHz -Return Loss ( 75 ohm):16dB (VSWR 1.38) Video to 500MHz -14dB (VSWR 1.38) 500 to 1500MHz -Connectors: F Fmale to F Female -Dimensions:1.385"L x 0.815"DIA.
Date published: 2013-06-10
Customer projects that include: Cable TV In-Line Coaxial Surge Protector
