ButtKicker RDB-120 Riser Stage and Raised Floor Kinetic Isolator 120 lbs.
Brand:|Model: RDB-120|Part # 300-9464
Maximize the impact of ButtKicker transducers with the ButtKicker RDB-120 120 lbs. kinetic isolators. Sold individually, mounting hardware sold separately.
List Price$16.95
You Save12%
$14.99
Part # 300-9464
  • Maximizes the effect of ButtKicker transducers
  • Mechanically isolates stages, platforms, and risers
  • 120 lbs. weight rating
ButtKicker's RDB-120 kinetic isolators maximize ButtKicker transducer performance when attached to ButtKicker enhanced raised flooring and stages or platform installations. Kinetic isolators (a minimum of three are recommended) act like springs and allow your platform to move freely and independently from other structures, allowing for focused ButtKicker power transfer.
RDB-120 kinetic isolators are rated to support up to 120 lbs. Each oil and corrosion-resistant molded neoprene isolator features a cast-in, drilled steel anchor/base plate and can handle static deflections of up to 1/2". The result is a much stronger effect without raising the volume level of the amplifier, and greater fidelity. Mounting hardware sold separately, see Related Items section. Sold individually. Designed to be used with bolts and screws with heads larger than 5/16".
Note: See pages 5 through 10 of the BK-LFE manual in the Manuals/Resources section for instructions.
  • ApplicationMounting & Accessories
  • BrandButtKicker
  • ModelRDB-120
  • Part Number300-9464
  • UPC898114000241
  • Product CategoryBass Shakers
  • Weight0.5 lbs.
View similar products to the ButtKicker RDB-120 Riser Stage and Raised Floor Kinetic Isolator 120 lbs.
in the Bass Shakers product category.
