300-9424_ALT_0
300-9424_ALT_1
300-9424_ALT_2
300-9424_ALT_3
300-9424_ALT_4
ButtKicker BKA300-4/NW 300W Transducer Power Amplifier with Wireless Remote Control
Brand:|Model: BKA300-4/NW|Part # 300-9424
ButtKicker built the BKA-300-4/NW digital low frequency power amplifier using BASH® technology for cool, fanless operation. Designed to power up to 4 mini Concert, 4 mini LFE, or 4 Advance ButtKicker transducers, it also includes a wireless remote control with 3 EQ settings.
OUT OF STOCK
Due In: 9/2/2016
List Price$299.95
You Save23%
$229.99
Part # 300-9424
  • BASH technology built-in
  • 2-ohm stable with up to 300W of output
  • Variable low pass filter
  • Wireless remote control with 3 EQ settings included
  • Includes vertical mounting stand and installation accessories
The ButtKicker BKA300-4/NW tabletop digital power amplifier is specifically designed as the perfect power partner for up to four BK-mini-CT mini Concerts (wired series-paralled), four BK-mini-LFE mini LFE (wired series-parallel), or two BK4-4 Advance ButtKicker transducers. Awesome features include: 2-ohm stability, variable 40 to 160 Hz low pass filter, 5-way binding post terminals, a wireless infrared remote control with intensity control and three preset EQ settings (Movies, Music, and Games), and IR in/out for daisy-chained amplifier control.
A Class D amplifier topology with BASH® technology was chosen for the BKA300-4/NW to keep efficiency high, and for its ability to be convection cooled with no need for a distracting cooling fan. One LFE RCA audio input, with 100 mV sensitivity, is paralleled to an RCA audio output for daisy-chaining amplifiers or connecting powered subwoofers. Banana plugs, a vertical mounting stand, an RCA dual female to single male Y-adapter, a 3 ft. RCA cable, and a high-to-low level signal adapter are included for quick connection and convenience.
Note: This amplifier is designed to be used with either 120 or 240 VAC power systems using the rear-mounted voltage selection switch. Ground loops can occur if this amplifier is connected to an ungrounded source. If you experience a ground loop, please use the groud loop isolator in the Related Items section.
Specifications: • Rated power output: 300 watts RMS into 4 ohms, 150 watts RMS into 2 ohms (current limited) • Frequency response: 10 to 300 Hz • Input sensitivity: 100 mV • Low pass adjustment: 40 Hz to 160 Hz (12 dB/octave) • Dimensions (H x W x D): 8.25" x 9.25" x 3.5" • Weight: 4.6 lbs.
  • Special FeaturesRemote Control
  • BrandButtKicker
  • ModelBKA300-4/NW
  • Part Number300-9424
  • UPC898114000487
  • Product CategoryHome Audio Amplifiers
    (3 Reviews)
  • Weight6.85 lbs.
View similar products to the ButtKicker BKA300-4/NW 300W Transducer Power Amplifier with Wireless Remote Control
in the Home Audio Amplifiers product category.
