Buffalo VC-5S-I Impedance Protected Volume Control Ivory
Brand:|Model: VC-5S-I|Part # 182-303
The VC-5S is two volume controls in one. Make your choice with the VC-5S jumper settings whether you need the impedance protection or not is up to you.
Comparable Items In Stock:
Part # 182-303
  • Selectable mode: Automatic impedance protection mode or No protection mode
  • Premium autoformers and an industrial strength build quality
  • Select desired mode with simple plug-in jumpers
  • Stylish low profile easy to grip knob
  • Mounts in any standard electrical box or P-ring
  • Available in decora or standard trim, color: white, light almond, or ivory
The Buffalo Electronics VC-5S is two volume controls in one. It is a VC-5A with the option to jumper out the impedance protection when it is not needed. The VC-5S works equally well in either mode but has the added responsibility of paying attention to the controlling jumpers while handling up to 150 watts of power. Smooth, soft detent 11 position switch, 10 volume levels + off position.
If you want to drive a single listening zone with its own amplifier this is the volume control for you. Without the protective circuit the volume level increases allowing a lower power, less expensive amplifier to be used.
Specifications: • Input Power: 50 Watts RMS (8 ohms) • Frequency response: 35 Hz - 40 kHz, + 0 dB - 2 dB • Insertion loss: 0.5 dB (obtained with superior quality autoformers) • Isolation: Left and right channels are completely isolated • Attenuation: Position 1 = off; Positions 2 - 7 = 1.5 dB, Positions 8 - 11 = 3.0 dB, Total attenuation = 25.5 dB, or no attenuation available.
  • TypeImpedance Protected
  • Control SurfaceRotary Knob
  • Wall Plate ColorIvory
  • BrandBuffalo Electronics
  • ModelVC-5S-I
  • Part Number182-303
  • UPC844632099236
  • Product CategoryIn-Wall Volume Controls
  • Weight0.96 lbs.
View similar products to the Buffalo VC-5S-I Impedance Protected Volume Control Ivory
in the In-Wall Volume Controls product category.
