Bravox UXP10D-2 Ultimate Performance Plus 10" DVC Subwoofer 2 Ohm Per Coil
Brand:|Model: UXP10D-2|Part # 269-525
Brazilian-made UXP Ultimate Performance Plus Series subwoofers from Bravox create maximum bass and require half the cabinet space of conventional subwoofers.
Part # 269-525
  • Patented 10" PGFC diamond-shape faceted cone with parabolic Santoprene surround
  • Extra large CONEX spider for superior excursion control
  • 300 watt RMS power handling
  • Made in Brazil by one of the most trusted speaker manufacturers in the industry
  • Lower than factory-direct prices
Through this Parts Express exclusive buyout, you can buy world-class Bravox drivers and accessories at or below the factory-direct price! Quantities are extremely limited; act fast, as a deal this good might not come along again for years!
The UXP Ultimate Performance Plus Series subwoofers from Bravox are purpose built to be the perfect balance of high SPL, low distortion, with small box requirements. To accomplish this, Bravox combines advanced acoustic engineering with state-of-the-art manufacturing techniques to create this ultra modern line of subwoofers.
For a solid foundation, Bravox starts with a stamped steel frame. The extra large CONEX® spider offers long term mechanical stability even during high excursion moments. A rigid PGFC (poly/glass fiber/ceramic) cone is molded with diamond facets, to reduce standing waves, and is mated to a parabolic Santoprene surround for linear excursion while maintaining a large piston area for quick, tight, clean bass.
The high 500°F temperature dual voice coil is mounted onto a Kapton® former for extreme power handling. Push button power terminals allow for maximum power transfer from your amplifier and keep wire connections secure.
Vance Dickason, writer of The Loudspeaker Design Cookbook, calls Bravox speakers, "...some of the best sounding speakers I have ever designed with. Highly recommended!"
Note: For box recommendations, please refer to the UXP Series Manual in the Manual/Resources section.
  • Nominal Diameter10"
  • Power Handling (RMS)300 Watts
  • Power Handling (max)600 Watts
  • Impedance2+2 ohms
  • Frequency Response30 to 1,500 Hz
  • Sensitivity88 dB 2.83V/1m
  • Resonant Frequency (Fs)35 Hz
  • DC Resistance (Re)1.8 + 1.8 ohms
  • Voice Coil Inductance (Le)0.64 mH
  • Mechanical Q (Qms)6.27
  • Electromagnetic Q (Qes)0.4
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)1.24 ft.³
  • Maximum Linear Excursion (Xmax)8 mm
  • Cone MaterialPoly Composite
  • Surround MaterialSantoprene®
  • Voice Coil FormerFiberglass
  • Overall Outside Diameter10.15"
  • Baffle Cutout Diameter9.21"
  • Depth5.79"
  • Sealed Volume0.34 ft.³
  • Sealed F374 Hz
  • Vented Volume0.8 ft.³
  • Vented F342 Hz
  • BrandBravox
  • ModelUXP10D-2
  • Part Number269-525
  • UPC789278709715
  • Product CategoryProducts
    (2 Reviews)
  • Weight11.45 lbs.
View similar products to the Bravox UXP10D-2 Ultimate Performance Plus 10" DVC Subwoofer 2 Ohm Per Coil
in the Products product category.
