Bravox PXW15D-2 15" DVC Subwoofer 2 Ohm Per Coil
Brand:|Model: PXW15D-2|Part # 269-523
Get the most bang-for-your-buck with a Brazilian Bravox PXW Series subwoofer! This world-class subwoofer is now available at lower than factory-direct pricing through this exclusive Parts Express buyout!
Part # 269-523
  • 15" injection molded cone with Santoprene surround
  • Santoprene spider resists fatigue
  • 320 watt RMS power handling
  • Made in Brazil by one of the most trusted speaker manufacturers in the industry
  • Lower than factory-direct prices
Through this Parts Express exclusive buyout, you can buy world-class Bravox drivers and accessories at or below the factory-direct price! Quantities are extremely limited; act fast as a deal this good might not come along again for years!
The PXW Series subwoofers from Bravox are purpose built to be the perfect balance of performance and value. To accomplish this, Bravox combines advanced acoustic engineering with state-of-the-art manufacturing techniques to create this ultra modern line of subwoofers.
For a solid foundation, Bravox starts with a stamped steel frame. A fatigue-resistant Santroprene® spider offers long term mechanical stability. A high stiffness, one-piece injection molded cone is used to resist deformation at high power levels and is mated to a Santoprene surround for linear excursion while maintaining a large piston area for quick, tight, clean bass.
The high 500°F temperature dual voice coil is mounted onto a Kapton® former for extreme power handling. 3 mm hex key power terminals are platinum-plated and allow for maximum power transfer from your amplifier and keep wire connections secure.
Vance Dickason, writer of The Loudspeaker Design Cookbook, calls Bravox speakers, "...some of the best sounding speakers I have ever designed with. Highly recommended!"
  • Nominal Diameter15"
  • Power Handling (RMS)300 Watts
  • Power Handling (max)640 Watts
  • Impedance2+2 ohms
  • Frequency Response20 to 2,000 Hz
  • Sensitivity89 dB 2.83V/1m
  • Resonant Frequency (Fs)23 Hz
  • Voice Coil Inductance (Le)0.57 mH
  • Mechanical Q (Qms)4.18
  • Electromagnetic Q (Qes)0.56
  • Total Q (Qts)0.5
  • Compliance Equivalent Volume (Vas)9.18 ft.³
  • Maximum Linear Excursion (Xmax)7.3 mm
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Overall Outside Diameter15.625"
  • Baffle Cutout Diameter14.125"
  • Depth7.125"
  • Sealed Volume5.17 ft.³
  • Sealed F337 Hz
  • Vented Volume14.4 ft.³
  • Vented F319 Hz
  • BrandBravox
  • ModelPXW15D-2
  • Part Number269-523
  • UPC789278709265
  • Product CategoryCar Subwoofer Speakers
    (2 Reviews)
  • Weight16.75 lbs.
View similar products to the Bravox PXW15D-2 15" DVC Subwoofer 2 Ohm Per Coil
in the Car Subwoofer Speakers product category.
