Bravox M6-IDB High Power 6" 2-Way Coaxial Marine Speaker Each
Brand:|Model: M6-IDB|Part # 269-515
Experience home quality high fidelity in your boat with Brazilian-made coaxial speakers from Bravox! These world-class speakers are now available at lower than factory-direct pricing through this exclusive Parts Express buyout!
Part # 269-515
  • 6" composite cone woofer with rubber surround and glass fiber frame
  • Neo-powered 1" aluminum dome tweeter
  • Made in Brazil by one of the most trusted speaker manufacturers in the industry
  • Lower than factory-direct prices
Through this Parts Express exclusive buyout, you can buy world-class Bravox drivers and accessories at or below the factory-direct price! Quantities are extremely limited; act fast, as a deal this good might not come along again for years!
Bravox designed their marine coaxial speakers to be the most sophisticated audio speakers ever built for marine installations. Each component that went into the build process was extensively tested to deliver high fidelity performance that can stand the test of time in the worst environments, including a unique waterproof Santoprene® rubber spider.
The M6-ID 6" is made structurally solid through the use of cast glass-fiber on both the protective grill and on the open 8-spoke frame. This provides a solid platform for great midrange and bass while offering superior protection against physical abuse.
A highly damped, composite woofer cone is used for smooth frequency response, and is mated to a Santoprene surround high SPL and low distortion. Extended accurate highs are delivered by the dedicated 1" aluminum dome tweeter. A mounting gasket and screws are included. Sold individually.
Vance Dickason, writer of The Loudspeaker Design Cookbook, calls Bravox speakers, "...some of the best sounding speakers I have ever designed with. Highly recommended!"
Specifications: • Power handling: 70 watts RMS/140 watts max • Impedance: 4 ohms • Re: 3.5 ohms • Frequency response: 60 to 20,000 Hz • 85 Hz • SPL: 90 dB 2.83V/1m • Vas: 0.28 cubic feet • Qms: 6.54 • Qes: 0.75 • Qts: 0.68 • Dimensions: Overall: 7.75", Cutout: 5.5", Depth: 2.875".
  • Speaker Type2-Way
  • Speaker Size6"
  • Power Handling (RMS)70 Watts
  • BrandBravox
  • ModelM6-IDB
  • Part Number269-515
  • UPC789278700606
  • Product CategoryProducts
    (1 Reviews)
  • Weight3.35 lbs.
View similar products to the Bravox M6-IDB High Power 6" 2-Way Coaxial Marine Speaker Each
in the Products product category.
