Bravox EXS12D-4 Extreme Duty 12" DVC Subwoofer 4 Ohm Per Coil
Brand:|Model: EXS12D-4|Part # 269-532
Bravox Brazilian-made subwoofers are purpose built for specific applications. The EXS Series Extreme Duty subwoofers are designed for maximum bass extension with minimum distortion.
Part # 269-532
  • 12" PMG cone with Santoprene surround
  • Santoprene spider resists fatigue
  • 500 watt RMS power handling
  • Made in Brazil by one of the most trusted speaker manufacturers in the industry
  • Lower than factory-direct prices
Through this Parts Express exclusive buyout, you can buy world-class Bravox drivers and accessories at or below the factory-direct price! Quantities are extremely limited; act fast, as a deal this good might not come along again for years!
The EXS Series Extreme Duty subwoofers from Bravox are purpose built to deliver extended bass response at a very low distortion level. To do so, Bravox combines advanced acoustic engineering with state-of-the-art manufacturing techniques to create this ultra modern subwoofer.
For a solid foundation, Bravox starts with a thick, rigid aluminum cast frame that increases power handling by acting as a heat sink. A fatigue-resistant Santroprene® spider offers long term mechanical stability.
A high stiffness injection molded PMG (poly/mica/glass) cone is used to resist deformation at high power levels and is mated to a Santoprene surround for linear excursion while maintaining a large piston area for quick, tight, clean bass.
The high 500°F temperature dual voice coil is mounted onto a fiberglass former. Gold-plated spring-loaded power terminals allow for maximum power transfer from your amplifier and keep wire connections secure.
Vance Dickason, writer of The Loudspeaker Design Cookbook, calls Bravox speakers, "...some of the best sounding speakers I have ever designed with. Highly recommended!"
Note: For box recommendations, please refer to the EXS Series Manual in the Manual/Resources section.
  • Nominal Diameter12"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance4+4 ohms
  • Frequency Response25 to 1,200 Hz
  • Sensitivity87 dB 2.83V/1m
  • Resonant Frequency (Fs)27 Hz
  • Mechanical Q (Qms)5.5
  • Electromagnetic Q (Qes)0.55
  • Total Q (Qts)0.5
  • Compliance Equivalent Volume (Vas)2.83 ft.³
  • Maximum Linear Excursion (Xmax)11 mm
  • Cone MaterialPoly Composite
  • Surround MaterialSantoprene®
  • Voice Coil FormerFiberglass
  • Overall Outside Diameter12.64"
  • Baffle Cutout Diameter11.14"
  • Depth5"
  • Sealed Volume1.74 ft.³
  • Sealed F343 Hz
  • Vented Volume4.55 ft.³
  • Vented F321 Hz
  • BrandBravox
  • ModelEXS12D-4
  • Part Number269-532
  • UPC7892787007715
  • Product CategoryProducts
    (4 Reviews)
  • Weight17.95 lbs.
View similar products to the Bravox EXS12D-4 Extreme Duty 12" DVC Subwoofer 4 Ohm Per Coil
in the Products product category.
