Bravox CS57K Kevlar Series 5"x7" Component Speaker System
Brand:|Model: CS57K|Part # 269-507
Experience home quality high fidelity in your car, truck, or van, with a Brazilian-made component speaker set from Bravox! These world-class speakers are now available at lower than factory-direct pricing through this exclusive Parts Express buyout!
Part # 269-507
  • 5" x 7" Kevlar woofer with aluminum former, rubber surround, and glass fiber frame
  • Liquid-cooled, neo-powered 1" aluminum dome tweeter
  • Surface and flush mounting hardware for the tweeter is included
  • Custom 4th-order 2-way crossovers with poly caps and user-selectable attenuation circuit
  • Made in Brazil by one of the most trusted speaker manufacturers in the industry
  • Lower than factory-direct prices
Through this Parts Express exclusive buyout, you can buy world-class Bravox drivers and accessories at or below the factory-direct price! Quantities are extremely limited; act fast, as a deal this good might not come along again for years!
Bravox component speaker sets represent the ultimate in car audio sound quality and are tuned to match perfectly with Bravox subwoofers. The CS57K 5" x 7" component speaker system was designed to provide a solid stereo image. A Kevlar® cone is used for the 5" x 7" woofer for extremely clean, accurate, and dynamic midbass, while a butyl rubber surround and Kapton® former voice coil offer durability and extreme power handling. A glass-fiber frame is used for a rigid, stable platform for highly detailed midrange and a Conex® spider provides long term mechanical stability.
A liquid-cooled, neodymium-powered 1" aluminum dome tweeter provides articulate frequency response, as well as high SPL, and can be flush or surface mounted using the included mounting hardware.
For seamless transition from the woofer to the tweeter, Bravox built the custom 4th-order Linkwitz-Riley 2-way crossover with a 0/-3 dB attenuation circuit switch that tailors the sound according to the installation. For low microphonics and longevity, Bravox only uses polypropylene capacitors in their crossovers.
Vance Dickason, writer of The Loudspeaker Design Cookbook and VoiceCoil Magazine editor, calls Bravox speakers, "...some of the best sounding speakers I have ever designed with. Highly recommended!"
Specifications: • Power handling: 80 watts RMS/160 watts max • Impedance: 4 ohms • Re: 3.3 ohms • Frequency response: 60 to 30,000 Hz • 85 Hz • SPL: 90 dB 2.83V/1m • Vas: 0.23 cubic feet • Qms: 3.5 • Qes: 0.98 • Qts: 0.76 • Xmax: 3.2 mm • Dimensions: Overall: 5.44" x 7.75", Cutout: 4.4" x 6.75", Depth: 2.75".
  • BrandBravox
  • ModelCS57K
  • Part Number269-507
  • UPC789278701214
  • Product CategoryProducts
  • Weight7.5 lbs.
View similar products to the Bravox CS57K Kevlar Series 5"x7" Component Speaker System
in the Products product category.
