269-500_ALT_0
269-500_ALT_1
269-500_ALT_2
269-500_ALT_3
Bravox CS50S 5-1/4" Component Speaker System
Brand:|Model: CS50S|Part # 269-500
Experience home quality high fidelity in your car, truck, or van, with a Brazilian-made component speaker set from Bravox! These world-class speakers are now available at lower than factory direct pricing through this exclusive Parts Express buyout!
  • 5-1/4" poly woofer with aluminum former, rubber surround, and glass fiber frame
  • Liquid-cooled, neo-powered 3/4" aluminum dome tweeter
  • Surface and flush mounting hardware for the tweeter is included
  • Custom high pass crossover with poly caps and user-selectable attenuation circuit
  • Made in Brazil by one of the most trusted speaker manufacturers in the industry
  • Lower than factory-direct prices
Through this Parts Express exclusive buyout, you can buy world-class Bravox drivers and accessories at or below the factory-direct price! Quantities are extremely limited; act fast, as a deal this good might not come along again for years!
Bravox component speaker sets represent the ultimate in car audio sound quality and are tuned to match perfectly with Bravox subwoofers. The CS50S 5-1/4" component speaker system was designed using state-of-the-art acoustic engineering to provide a solid stereo image. An injected-molded cone is used for the 5-1/4" woofer for smooth frequency response, while an overmolded TPR Santoprene® rubber surround and heavy-duty aluminum former voice coil offer durability and extreme power handling. A glass fiber frame is used for a rigid, stable platform, for highly detailed midrange.
A liquid-cooled, neodymium-powered 3/4" aluminum tweeter provides extended, accurate highs, and can be flush or surface mounted using the included mounting hardware. For seamless transition from the woofer to the tweeter, Bravox built the custom high-pass crossover with a 0/-3 dB attenuation circuit switch that tailors the sound according to the installation. For low microphonics and longevity, Bravox only uses polypropylene capacitors in their crossovers.
Vance Dickason, writer of The Loudspeaker Design Cookbook and VoiceCoil Magazine editor, calls Bravox speakers, "...some of the best sounding speakers I have ever designed with. Highly recommended!"
Specifications: • Power handling: 60 watts RMS/120 watts max • Impedance: 4 ohms • Re: 3.5 ohms • Frequency response: 70 to 22,000 Hz • 90 Hz • SPL: 88 dB 2.83V/1m • Vas: 0.14 cubic feet • Qms: 6.25 • Qes: 0.63 • Qts: 0.57 • Xmax: 2.3 mm • Dimensions: Overall diameter: 6", Cutout diameter: 5.5", Depth: 2.25".
  • BrandBravox
  • ModelCS50S
  • Part Number269-500
  • UPC789278710780
  • Product CategoryComponent Speaker Systems
  • Weight4.75 lbs.
View similar products to the Bravox CS50S 5-1/4" Component Speaker System
in the Component Speaker Systems product category.
