Bravox BVX12D-2 12" DVC Subwoofer 2 Ohm Per Coil
Brand:|Model: BVX12D-2|Part # 269-521
Bravox Brazilian-made subwoofers are purpose built for specific applications. The BVX Series subwoofers are designed for maximum SPL with minimum distortion.
Part # 269-521
  • 12" PMCF cone with parabolic Santoprene surround for SPL use
  • Santoprene and CONEX spiders on a polycarbonate platform
  • High 1,200 watt RMS power handling
  • Made in Brazil by one of the most trusted speaker manufacturers in the industry
  • Lower than factory-direct prices
Through this Parts Express exclusive buyout, you can buy world-class Bravox drivers and accessories at or below the factory-direct price! Quantities are extremely limited; act fast, as a deal this good might not come along again for years!
The BVX Series subwoofers from Bravox are purpose built to deliver massive SPL, extended bass response, and to do so at a very low distortion level. To do so, Bravox combines advanced acoustic engineering with state-of-the-art manufacturing techniques to create this ultra modern subwoofer.
For a solid foundation, Bravox starts with a thick, rigid aluminum cast frame that increases power handling by acting as a heat sink. Dual extra large CONEX® and Santroprene spiders are assembled atop a polycarbonate vented base for efficient voice coil control during high excursion moments and offer long term mechanical stability.
A high stiffness injection molded PMCF (poly/mica/glass/carbon fiber) cone is used to resist deformation at high power levels and is mated to a parabolic Santoprene for linear excursion while maintaining a large piston area.
The high 500°F temperature 2.5" four-layer dual voice coil is mounted onto a fiberglass former for an extreme 1,200 watt RMS power rating. Platinum-plated 4 mm hex head power terminals allow for maximum power transfer from your amplifier and keep wire connections secure.
Vance Dickason, writer of The Loudspeaker Design Cookbook, calls Bravox speakers, "...some of the best sounding speakers I have ever designed with. Highly recommended!"
Note: For box recommendations, please refer to the BVX Series Manual in the Manual/Resources section.
  • Nominal Diameter12"
  • Power Handling (RMS)1,200 Watts
  • Power Handling (max)2400 Watts
  • Impedance2+2 ohms
  • Frequency Response25 to 1,200 Hz
  • Sensitivity86 dB 2.83V/1m
  • Voice Coil Diameter2.5"
  • Resonant Frequency (Fs)32 Hz
  • DC Resistance (Re)1 + 1 ohms
  • Voice Coil Inductance (Le)0.98 mH
  • Mechanical Q (Qms)9.5
  • Electromagnetic Q (Qes)0.55
  • Total Q (Qts)0.52
  • Compliance Equivalent Volume (Vas)1.73 ft.³
  • Maximum Linear Excursion (Xmax)11 mm
  • Cone MaterialPoly Composite
  • Surround MaterialSantoprene®
  • Voice Coil FormerFiberglass
  • Overall Outside Diameter12.875"
  • Baffle Cutout Diameter11.65"
  • Depth6"
  • BrandBravox
  • ModelBVX12D-2
  • Part Number269-521
  • UPC789278707261
  • Product CategoryProducts
  • Weight27.85 lbs.
View similar products to the Bravox BVX12D-2 12" DVC Subwoofer 2 Ohm Per Coil
in the Products product category.
